Originally posted by MikeyBugs95 In the side-by-side comparison pictures on page 32 of my browser, the card door looks to be the exact same size as the door on the K-3II.
Actually, that side of the camera looks
quite identical to the K-1.
Even the two screws to the right of the card door are positioned the same way, the card door is not only the same size, but the same shape and has the same recessed finger grip thingy. The remote connector has the same rubber plug on it - and there is the one slight difference between the K-1 and this unnamed newcomer: card door and remote plug don't align the same way on the right side as they do on the K-1.
The hand grip on the front and the thumb grip on the back are more than inspired by the ones found on the K-1.
Both cameras differ hugely on the top plate, where the various control wheels are located. Quite obviously, since the LCD, the control knob's layout and all that stuff has changed, not to mention the pentaprism cover. No wonder, being an APS-C camera, the pentaprism hiding under this cover is much smaller than the one found in the full-frame K-1.
Originally posted by Rondec I haven't heard of knobs failing on the K-1. Was this a common occurrence or something that you read one thread on and generalized to "a number of people?"
Yes, it was quite common to early copies sold in 2016. Mine had that failure too, stuck in "M" mode. Warranty repair solved that, since then the camera is as perfect as it is (and no, I won't downgrade to the K-1 II).
