11-06-2019, 02:29 AM - 1 Like   #1
Mistral75's Avatar
Ricoh WG-6 and G900 firmware updates + DC Software II update
Ricoh released firmware update version 1.02 for the WG-6 camera.
QuoteOriginally posted by Ricoh Imaging:
Changes to V1.02
  • [Pix.Track SR] can be selected in CALS mode.
  • The sequence for Interval Shooting and Interval Movie shooting has been reviewed and improved battery life.
  • Improved stability for general performance.
Changes to V1.01
  • Improved the power control when the power is turned off with the GPS function ON.
  • Improved the phenomenon that noise is rarely generated in the image that could not be processed shake reduction when the electronic Shake Reduction mode was turned on.
Source: Latest RICOH WG-6 Firmware Update : Software Downloads | RICOH IMAGING
Ricoh also released firmware update version 1.01 for the G900 camera.
Changes to V1.01
  • Improved the battery life of using "Interval Shooting" and "Interval Movie" uses with revised sequences.
  • Added choices newly to the following items in the “Shooting menu” of “CALS mode”.
    • Pix. Track SR: ON
    • ISO Setting: 12800, 25600
  • Corrected EX2 to be able to output the serial number information of G900 (EX2 Version 1.0.1.8 is required.)
Latest G900 Firmware Update : Software Downloads | RICOH IMAGING
Ricoh further released update version 1.01 to DC Software II (G900 / G900SE).
  • DL-20 (Ver. 1.0.0.4) - sends files to PC with USB connected
  • EX2 (Ver. 1.0.1.8) - change file name based on memo data
  • LE2 (Ver. 1.0.1.0) - create camera memos
  • ME2 (Ver. 1.0.1.0) - view and manage files with camera memos
  • When installing DC Software II, it has enabled to select "All Users" or "Login Users" as using the software.
  • Corrected to enable to output G900 serial number information by using EX2.
    (G900 firmware version ver. 1.01 is required.)
  • Corrected that EX2 outputs camera memo information.
Latest DC Software Firmware Update : Software Downloads | RICOH IMAGING
11-06-2019, 07:47 AM   #2
sbh
sbh's Avatar
Thanks!
11-06-2019, 07:50 AM   #3
Mistral75's Avatar
You're welcome!
11-27-2019, 01:50 AM   #4
Mistral75's Avatar
Ricoh released firmware update version 1.01 for the G900SE camera.
Changes to V1.01
  • Improved Bluetooth function.
    • Pix. Track SR: ON
Latest G900SE Firmware Update : Software Downloads | RICOH IMAGING
02-20-2020, 05:15 AM   #5
Mistral75's Avatar
Ricoh just updated DC Software II (G900 / G900SE).
  • DL-20 (Ver. 1.0.1) - sends files to PC with USB connected
  • EX2 (Ver. 1.0.3) - change file name based on memo data
  • LE2 (Ver. 1.0.2) - create camera memos
  • ST-20 (Ver. 1.0.0) - wireless LAN setting for G900SE, G800SE and G700SE
  • SR-20 (Ver. 1.0.1) - FTP server for G900SE, G800SE and G700SE
  • Corrected so that EX2 can extract more than 128 bytes of a bar-code data which is recorded in an image file.
  • Corrected that firmware update can be available by SR-20's FTPs. It takes longer to update the firmware than its FTP.
  • Simplified Chinese is displayed on Chinese OS. (DL-20, EX2, LE2, ME2)
G900: Latest DC Software Firmware Update : Software Downloads | RICOH IMAGING
G900SE: Latest DC Software Firmware Update : Software Downloads | RICOH IMAGING
07-01-2020, 09:46 AM   #6
Mistral75's Avatar
Ricoh released firmware update version 1.02 for the G900SE camera.
Changes to V1.02
10-29-2020, 05:22 PM   #7
Mistral75's Avatar
  1. Ricoh Imaging released firmware update version 1.03 for the WG-6 camera.
    Changes to V1.03
  2. Ricoh Imaging released firmware update version 1.02 for the G900 camera.
    Changes to V1.02
    • Improved stability for general performance[
  3. Ricoh Imaging released firmware update version 1.03 for the G900SE camera..
    Changes to V1.03
  4. Ricoh Imaging updated DC Software II (G900SE).
    • EX2 (Ver. 1.0.4 ) - change file name based on memo data
    • ME2 (Ver. 1.0.1) - view and manage files with camera memos
    • ST-20 (Ver. 1.0.1) - wireless LAN setting for G900SE, G800SE and G700SE
    • SR-20 (Ver. 1.0.2) – FTP server for G900SE, G800SE and G700SE All are not supported multisession.
    • Corrected so that EX2 works to convert correctly the camera memo data including the character code "0x5c" in the picure file under Windows 7 SP1 or Windows Server 2008 R2.
    • It is changed from "Infrastructure STA" to "Infrastructure AP" about the initial value of "Connection Config" in "Web Server Options" tab. (For "Image Sync" app connection).
02-05-2021, 04:02 PM   #8
Mistral75's Avatar
Ricoh Imaging released firmware update version 1.04 for the WG-6 camera.
Changes to V1.04
02-09-2021, 12:45 PM   #9
retired sw engineer
reh321's Avatar
QuoteOriginally posted by Mistral75 Quote
Most of the firmware updates listed here have the line "improved stability for general performance" in them.
I learned many years ago that the most stable software undergoes few changes - making changes may correct some causes of instability, but it invariably contains news sources of instability.
02-09-2021, 12:57 PM   #10
QuoteOriginally posted by reh321 Quote
Are you saying that Ricoh Imaging releasing firmware updates is something bad?
02-09-2021, 01:13 PM   #11
retired sw engineer
reh321's Avatar
No, I was just commenting on something I noticed.
I would want to know more before I would spend my cash on one of these cameras.
camera, dc, downloads, firmware, pentax news, pentax rumors, ricoh, software, ver, version
Ricoh WG-6 & WG-60? csa Pentax Compact Cameras 7 04-21-2020 10:49 PM
Ricoh WG-6 / G900 / Theta Z-1 get delayed Mistral75 Pentax News and Rumors 59 05-24-2019 02:00 AM
Optio WG-3 GPS, WG-3, and WG-10 Outdoor Compacts officially Announced Adam Pentax News and Rumors 13 02-03-2013 03:02 AM
PENTAX WG-10, WG-3 GPS and WG-3 is Coming!!! ogunturkay Pentax News and Rumors 39 01-29-2013 10:00 AM
Software and firmware updates for K-7 offthebeatenpath Troubleshooting and Beginner Help 3 01-24-2011 08:17 PM
All times are GMT -7. The time now is 01:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
