Originally posted by bxf There have been many references to improved SDM on the older DA* lenses, but I've never encountered anything definitive regarding this. I think there was even some statement made by a Pentax technician to that effect, but this was never corroborated.
Are you in a position to enlighten us on this with any specific information? Is there a date or serial number that one could reference to determine whether a given lens is pre or post SDM update?
As you know, there was no need to update the motors in the vast majority of SDM lenses.
However, it seemed once failed, another failure was imminent.
Pentax quietly upgrade the AF drive under warranty with better components when repaired, as confirmed by the German technician, and started using them on their production lines, but saw no need to encourage a wholesale up date since so many units worked as advertised.
It would have been irresponsible to offer an upgrade to working lenses that had nothing wrong with them given that they were the vast majority.....
But hey, we've been over this a million times, no one's going to change their minds now. Just saying, there are a lot of ways of looking at this, and in some of them, Pentax doesn't look as bad as many have made out.
My speculation was that the original motor wasn't strong enough to cover the torque needed if components at the high and low end of spec. came together to produce more friction than the motor was designed to overcome. A case of over engineering a product with not enough attention paid to the minimum and maximum torque need to run the AF system based on predictable variation using the accepted specs for various components. I'm not sure how only upgrading only the lenses that needed it was a bad thing. The biggest complaints came from people who's lenses were the worst.They had a tight lens, they sent it in. Their motors were replaced with the same motors that failed the first time, and they failed again, because the problem was too much friction in the AF drive, not the motor.. In benjikans case the first time he used it at high end magazine cover photo shoot it failed within minutes of being put on the camera.. Those people deserved some special consideration.
That's my take anyway, and no one is ever going to confirm it, so file it in the circular file if you wish.
Bottom line, every electric motor is going to fail eventually. Replacing the drive with every new camera body as in screw drive was always going to be the most reliable, for any system. If you want lens that might be working 20 years from now, my guess is get screw drive and buy the last system available before KAF4 is all that comes in new camera bodies.
