04-13-2020, 03:10 PM   #31
QuoteOriginally posted by Mistral75 Quote
1/ I posted three examples taken with the Trioplan 100mm f/2.8 II, the 'OPC Trioplan', in the first post of this thread.
2/ Answer #15 by @D1N0
3/ Answer #16 by @edri
It seems to me the references made here are to the pictures I posted, i.e. the 'OPC Trioplan', not the 'net SE Trioplan'.
It seems to me, you forgot one reference. Anyway, there is no comparison, but only statements.
The attitude towards this Cooke triplet 100mm lens, that is reflected here, without having 1:1 comparisons available, I do not understand.
04-14-2020, 12:57 AM   #32
QuoteOriginally posted by Serkevan Quote
On a positive note, our Pentacon 200mm f/4 is on the way (16€ with delivery!), with all its glorious 15 blades. I also got a couple adapters (M42-EF and M42-PK). As I don't plan to use this lens for anything other than portraits or close focus bokeh shots, I chose a cheap flanged adapter to avoid having to cover the mount - I'm lazy like that and the original Pentax M42-PK adapters seem to have vanished from Europe...
Bristol Cameras Pentax M42 To K Mount Bayonet Body Mount Adapter - Best Price at Bristol Cameras are still advertising the original as "available to order" ... might be worth asking, if you're interested, but I'll agree, the flanged adaptor makes a lot of sense in most circumstances
---------- Post added 04-14-20 at 01:02 AM ----------
QuoteOriginally posted by reh321 Quote
I have shot with several M42 lenses {including the Takumar 50mm, Mir 37mm, and Takumar35mm) and never needed to 'cover the mount'.
Mostly it's not an issue, but my Helios-44-2 especially (not the later models or the Industar-50-2) and a couple of my early 135mm lenses are slim enough to leave the gaps exposed. It's the gap nearest the shutter button that causes a problem, according to a couple of basic tests I made with a torch in a dark room, a stretchy hair-band solves the issue
04-14-2020, 06:57 AM - 1 Like   #33
retired sw engineer
reh321's Avatar
QuoteOriginally posted by kypfer Quote
I admit to having just a few M42 lenses - all vintage lenses like the Takumar 50mm, and I have zero problems with the original adapter. I do have a flanged adapter, but it makes no sense at all, because it does eliminate infinity focusing, and the few times I use an M42 lens, I use it as a 'regular' lens.
04-14-2020, 09:53 AM - 8 Likes   #34
antipattern's Avatar
I do love the Primoplan and hope that will be one of the next lenses they will re-release. I have two original M42 versions, one standard and one in the mini-body. The rendering is something quite special and the lens is a good performer given its age. The mechanics and coatings are not that amazing, particularly with the K-Mount adapter, which other people have mentioned already, so a native K-Mount version would be nice to have. I regret not having picked up the K-Mount version when it was on sale for €450, but I'm not sure I'd be willing to spend €999 on it...
The same holds for the Trioplan 100. It's a speciality lens, and the bokeh can make or break a photo depending on the circumstances. A smooth bokeh is just a stylistic choice, and not every photo will benefit from it. The FA43 ltd can have a harsh OOF rendering, too, but in the right context the background can look like an impressionist painting by Monet or Renoir.
I hope OPC has retained the characteristic rendering (because what's the point otherwise?), but those photos are too early to tell. The original Trioplan doesn't bubble in every photo and for every OOF highlight, but is a bit selective, e.g. bubbles here:
compared to a more characteristic example of the Trioplan 100 bokeh:
The Pentacon/Meyer Orestor 100mm and 135mm lenses have a very different, much smoother image characteristic, but even other triplets don't bubble as much. So even slight changes in design might reduce the bubbles, and if the bubbling characteristic has been reduced it kinda defeats the purpose of the lens. It's a shame that the sample photos provided by OPC don't show the typical Trioplan-bubbles, and I hope that that's just because they picked unrepresentative photos, rather than the lens behaving differently.
04-15-2020, 01:04 AM   #35
Great images. The rendering should be a feature of the cooke triplet lens design (or modified cooke triplet in case of the primoplans).It is present across the different focal length lenses, available. Whether you modify the mechanics or move to modern glass should not really impact the out of focus rendering, but compairative images would show. It is also that out of focus rendering, why a lot of professsional photographers go for that lens (and not so much for the bubble effect).
04-15-2020, 02:55 AM - 3 Likes   #36
Jean Poitiers's Avatar
Hi and thanks for the info !!! Nice to know.
There is an alternative if one is seeking for this type of "look" ... slide projector lenses.
I posted these images yesterday after a quick construction of a new rig using an Aldis Star Anastigmat 100mm f/2.8 projector lens on the Fuji X-E2 as a first test. I picked up the lens at my thrift store attached to a working slide projector for 6€.
Here's the x-post of those images and here's the thread if one is curious about slide projector and other simple lenses ... The "Projector Lens" Club ... - PentaxForums.com
A new entry ... an Aldis Star Anastigmat 100/2.8 projection lens wide open on my Fuji X-E2. This lens has its own helicoid housing and I have mounted it for now in a large Chinese K-mount extension tube. I have infinity and will share a few more images later on ... here, some rushed tests out in my backyard before I had to get diner on the table. Ha!
04-15-2020, 03:46 AM - 8 Likes   #37
Inverting the front element on a Zenitar 50mm will also work.
Inverting the front element on a Helios 44-2 is a bit of fun, too ...
04-15-2020, 10:52 AM - 1 Like   #38
Mistral75's Avatar
Meyer Optik Görlitz Trioplan 100mm f/2.8 II. Source: Facebook
04-16-2020, 06:55 AM   #39
Hi again.
Check out this YouTube video at about the 2 and a half minute mark ... the projector lens makes a pretty good showing against the Meyer Optik Trioplan 100/2.8 II ... https://youtu.be/uL6NjJPqCIg?t=150
Entire video ⇒
04-16-2020, 07:42 AM   #40
That is quite a bargain, compared to trioplan.
QuoteOriginally posted by Jean Poitiers Quote
04-16-2020, 10:48 AM   #41
MJKoski's Avatar
Do these bubblegum-lenses work with infrared? Construction seems simple enough to not cause huge flaring and hotspot ping-pong games with the sensor cover glass. Funny enough, one of my best IR lenses is now EM Ennalyt 35mm from 1960 or so.
04-17-2020, 12:56 AM   #42
QuoteOriginally posted by MJKoski Quote
I've yet to try one of my triplets with an infra-red filter, the filter-thread on my Trioplan is too small to suit my existing filters. I'll have a go with my Domiplan, or my Cassaron (if I can get the aperture to behave itself) and report back ... might be interesting
FWIW, I've had some infra-red success with a Pentacon 29mm f/2.8 and a Fujinon 28mm f/3.5 in recent days, on my *ist DL2, but I've yet to try any of my Enna lenses
04-17-2020, 02:50 AM   #43
MJKoski's Avatar
Thanks, I am interested in that circle bokeh. Might be funky with IR-Chrome and other nice filters.
04-17-2020, 04:05 AM - 1 Like   #44
Mistral75's Avatar
Meyer Optik Görlitz Trioplan 50mm f/2.8 II. Source: Facebook
04-18-2020, 09:51 AM   #45
Took my Domiplan for a walk this afternoon, Meyer Optik's later incarnation of their 50mm triplet, from the '60's ... seems to be fine with a Lee 87 on the front. Just one minor issue, the filter thread rotates as the aperture is changed ... bit of a nuisance with a Cokin holder and square hood
The camera is my unmodified *ist DL2 , 0.5sec @ f/8 200ASA
adapter, adapters, cameras, couple, ii, issue, lens, lenses, m42, m42-pk, meyer, mount, optics, optik, pentax, pentax news, pentax rumors, primoplan, products, trioplan
(Rare?) Meyer Optik Görlitz Primotar 50mm f/2.8 (M42) Helix Pentax SLR Lens Discussion 16 06-02-2018 01:57 AM
New K-lenses from Meyer Optik Görlitz : who tested ? Gedeon Pentax SLR Lens Discussion 14 01-03-2018 03:12 AM
Meyer-Optik Görlitz kickstarter campaign fs999 Pentax SLR Lens Discussion 20 04-28-2016 04:45 PM
Meyer-Optik Görlitz Orestor 135mm f/2.8 BKSPicture Lens Sample Photo Archive 0 09-08-2014 09:53 AM
Misc Some simple real life test shots with the Meyer-Optik Görlitz Orestegon 29mm/F2.8 Rense Post Your Photos! 14 02-09-2011 09:18 AM
All times are GMT -7. The time now is 02:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
