Originally posted by pres589 I never really attached max aperture to a requirement with the Limited's. Lots of other things about them (they should be small, top build quality, 'pleasing' rending over clinically sharp at all apertures, etc). I hope that continues to be the case going forward.
But interestingly, a max. aperture of f2 or faster was a design goal for the FA Limited series from the start. The first one was the 43mm and that focal length was decided specifically because they wanted to make a lens faster than f2 with a filter diameter of 49mm. Their simulations indicated that 43mm was the best choice to stay within those constraints.
It's already clear that they won't stick to those same constraints for the 21mm (we already know it's bigger and slower), but I don't think they will stray too far. Also, as Wheatfield says, technology and expectations have moved on, so what they can achieve now in wide open sharpness is probably a lot better.
One other thing that was clear from the presentation I saw about the Limited was that the consistency of rendering throughout the aperture range is something that they prioritize with star lenses, but not with Limited lenses. With the limited lenses they view the change in character when you stop down as something they want to retain. It makes it a less consistent but potentially more interesting instrument to use. Think about the 77mm. You have the wide open bokeh performance, the close focus ability at f2.4, the impressive sharpness at f5.6 and the starburst ability when stopped right down. So in a sense you are getting a lens capable of acting like several different lenses in one.
