Originally posted by Rondec I think it's release price will likely be in the 1500 dollar range, maybe a bit higher.
The whole point of limiteds in the past was small size, metal build, and interesting rendering. This lens is going to be a bit bigger which speaks to me of more corrected optics as well as the in lens motor. It will surely have excellent contrast, minimal fringing, and minimal flare. If it matches these sorts of things, I'll definitely be in line for one. This is about the perfect focal length to me and would be so much more portable than the DFA 15-30.
To me the HD Pentax-D FA 21mm ED Limited DC WR being longer than the smc Pentax-FA 31mm f/1.8 AF ED Limited speaks first and foremost of a much shorter focal length, less than half the back focal distance, hence a retrofocus / inverted telephoto design with a front group of much higher negative power, hence:
- an optical centre farther from the front group, hence a longer lens and
- much more pronounced aberrations to be corrected (distortion, coma, lateral chromatic aberrations and more), hence more elements in both groups, the front negative group and the rear positive group, including more aspheric elements and/or more elements made of special glass, hence a more expensive lens
all other things being equal.
Add higher image quality requirements (lesser drop in sharpness outside the centre, aberrations better corrected) on top of the constraints arising from the shorter focal length and you'll obtain an even bigger and more expensive lens.
