Originally posted by Mistral75 I'm not so sure D FA 21 Limited sample lenses are already out for testing. Except by Ricoh Imaging employees of course.
As for NDAs, I have written many but none involving Ricoh Imaging.
I wonder if it would be possible in the K-mount as-is to have a change in maximum aperture based on which format camera you had...
If a lens had soft edges wide open on full frame, for example, but was fine on APS-C, could the camera be told to only allow the geometric maximum aperture only on APS-C and stop down a touch on full frame?
Then which would you put on the lens? If it was f2.8 on full frame but f2.5 on APS-C, which would you use on the label?
Not that I'm suggesting specifically that is what was actually done on the DFA 21, just asking if it could be done... are the K-mount lens protocols that sophisticated?
And that's almost exactly the response I would expect if you were under a NDA to Ricoh Imaging
-Eric
