04-05-2021, 11:40 AM   #301
QuoteOriginally posted by ThorSanchez Quote
They have both a 70-200 f/2.8 at about $1500 and a 70-210 f/4 at $1000, so I think a 150-600 at somewhere around $1000 would be a nice compliment to the $2000 150-450.
$1000 isn't realistic, I wonder if $1500 would be... The Tamron had a MSRP of $1400, right? And a Pentax version would be at least slightly more expensive.
04-05-2021, 11:47 AM   #302
Looks like you’re right on the $1400 MSRP. $1500 or $1600 could be realistic then. The price differential between the Tamron and Pentax versions of the 70-210 and the 15-30 is not consistent enough to predict.
04-05-2021, 11:48 AM   #303
QuoteOriginally posted by Serkevan Quote
Unless you're in Europe, where the 70-200/2.8 is 2300€
It's actually 100€ more expensive than the 150-450 over here...
I was off a little, it's $1800 here in the States, and the 150-450 is $2000. Probably because the only way I'd ever get either is used, and I could get them for $1500, perhaps a bit less.
Still, I'd like a 150-600 at $1000 or so, even if it's not * quality...
---------- Post added 04-05-21 at 02:51 PM ----------
The Tamron is about $1200 on B&H and Amazon. So maybe $1300-1400 for a Pentax model? Although the 70-210 is 50% more for the Pentax version, so that would be $1800 and... yikes.
All I know is that the K-3 III is going to be more than double what I've ever spent on any photography gear, so it'll probably be a long while before I spend $1000+ on anything like that.
04-05-2021, 12:02 PM - 1 Like   #304
no, no, no, no, no. No talk of consumer zooms please. Pentax is iterating those way to much. We still need fast primes for both apsc and ff. They are allowed to do the DA*1650 but that's it
04-05-2021, 12:04 PM - 1 Like   #305
Mike.P®'s Avatar
I am currently selling my K-1, 15-30mm, 24-70mm, 70-200mm, Sigma 85mm and 180mm macro to buy a Sony body and the 200-600mm purely because Pentax doesn't have a ** - 600mm lens. I am keeping my 150-450mm, 1.4x and a couple of crop lenses for later in the year when I may buy the K-3 III but IMO without a longer prosumer zoom lens Pentax won't attract the wildlife shooters no matter how good the AF is.
04-05-2021, 01:54 PM   #306
How well does the DA560 work with the DA1.4x? I wonder how that would translate to a full frame 1.4x...
Outside of really fast telephoto, you could do much worse than the K3iii and the 11-28, 16-50, 150-450, 560, and the 1.4x. Throw in a few primes and/or the 55-300, and you have a beautiful system.
-Eric
04-05-2021, 02:03 PM   #307
QuoteOriginally posted by TwoUptons Quote
-Eric
A K-3 III without a 55-300 PLM is like Fred Astaire without Ginger Rogers.
04-05-2021, 02:14 PM   #308
The DFA*70-200 f2.8 would be maybe Cyd Charisse? 😛
-Eric
04-07-2021, 03:10 AM   #309
There is a full frame 55-ish to 300-ish lens on the roadmap now. I think that’s a good place to focus, especially if it can come close to the DA55-300 PLM focusing speed.
Interestingly, it's the same distance on the cropped and FF list. Might be one zoom covering both sensor sizes. An update of the 60-250mm which actually covers FF although it's a DA*?
But it doesn't quite reach 60 on that table. That lens has a good reputation, I read (as I never owned it), but the AF came in for criticism.
04-07-2021, 05:30 AM   #310
QuoteOriginally posted by Smolk Quote
If it covers full frame, APS-C won’t be an issue, but I can’t see it being a 60-250 replacement since it isn’t listed as a * lens, and we have the DFA70-210 f4 as a “not-*” full frame lens.
And I can’t imagine Pentax labeling a DA* lens as a DFA, but I could imagine them selling a DA* lens that happened to work fine (though not to * standards) on full frame.
I think the zoom on the roadmap is meant to complement the DFA28-105 on full frame, but it would obviously work fine on an APS-C. I also expect a variable aperture. So not a limited or * lens, just a “regular” lens, though what that means has shifted a bit in the past 30 years or so
-Eric
04-07-2021, 05:36 AM   #311
Dunno. If they want to sell/advert K-3/3 as wildelife/action camera then lens setup able to get the best out of new AF is required. And after 16-50 it will lack only something longer the 300. Of course there is DA* 560 but it is the "end of the road" for DA currently, with nothing between it and 55-300 PLM.
Though who knows what people at Ricoh are thinking and what will make next. Filling up FF lenses with modern updates may be a preparation for K-1 Mk III.
04-07-2021, 05:55 AM   #312
As far as I can see, the lens is coloured red: neither yellow for a star lens, nor green for a non-star lens. Hence it has either not been decided or it is a ‘detail’ not yet disclosed.
As we already have 70-200 and 70-210, another one in this range would be overkill. 70-250? Too similar imo although that's what it looks like, admittedly. Is that what you think of as a companion to the 28-105 FF?
04-07-2021, 06:22 AM - 1 Like   #313
Zygonyx's Avatar
QuoteOriginally posted by jersey Quote
Don't you know about DFA150-450 ?
04-07-2021, 06:34 AM   #314
acoufap's Avatar
QuoteOriginally posted by Zygonyx Quote
... and combined with the DA TC 1.4x it‘s FOV is approximately that of a f8 / 950mm lens using an FF camera.
04-07-2021, 06:35 AM   #315
retired sw engineer
reh321's Avatar
QuoteOriginally posted by house Quote
As long as Pentax is manufacturing 'consumer-level' bodies such as the K-70, they need to support them with 'consumer-level' lenses.
In fact, as long as they are using solenoid-based aperture control in them, they need to think in terms of KAF4 - but certainly not something as costly as the DA* 16-50mm.
Yes, I know you want a complete set of "star" prime lenses, but other people have wants also - we can share.
The 55-300mm PLM is fine for telephoto - but they also need to think in terms of a 'standard' lens - perhaps a DA 18-55mm in KAF4.
16-50mm f2.8ed plm, 85mm, apsc, barrel, batch, da * 16-50mm, fa*, ff, filter, focus, hd, hd pentax da, infinity, lens, lenses, optics, pentax, pentax news, pentax rumors, pentax-d, pentax-da, plm, post, price, sdm, tamron, thread, units
HD PENTAX-DA★11-18mm F2.8ED DC AW ramseybuckeye Pentax SLR Lens Discussion 94 11-13-2020 09:46 AM
For Sale - Sold: DA and HD DA Primes: DA 50 1.8, DA XS 40mm, HD DA 35mm, DA 21mm, HD DA 15mm Amarony Sold Items 8 02-20-2019 06:21 AM
Photo Life News letter - HD PENTAX-DA★11-18mmF2.8ED DC AW and the HD PENTAX-FA35mmF2 jpzk Photographic Industry and Professionals 4 02-04-2019 08:15 AM
For Sale - Sold: HD Pentax-D FA 70-200mm F2.8ED DC AW hgbisel Sold Items 4 08-29-2017 07:01 PM
All times are GMT -7. The time now is 06:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
