Originally posted by licht96 @Bigmaccam: on the new K3 III.
I also checked the old K3 II. There is no problem (but the field of AF points is not so big, as you know).
I think, I will open a topic here in the forum, that someone can check all the AF points, too.
May be, I've a bad copy (but it's already the second one)
OK... So:
- Subject with big stomach (
) centered in viewfinder
- Focusing through the viewfinder (i.e. using PDAF)
- Outer focus point selected, positioned on the face
- Focus using AF, and take the shot
In this instance, are you saying the face is not in focus, or the stomach? If the face is in focus - i.e. the point on which the outer focus point was centered - then it's working correctly. The stomach may be out of focus, potentially due to depth of field (solution: subject needs to lose some weight
) or field curvature (solution: learn to work with it
If the face isn't in focus using this example, try the same thing in Live View. Does this work? Assuming it does, then PDAF is the culprit. It could be that your camera needs factory adjustment of the focus point offsets.
