Originally posted by rawr That would be a very interesting development. I've often thought that Pentax has been under-utilising the capabilities of the current RGB metering sensor. But the 'resolution' of the metering sensor would probably have to be improved in order for that sensor to do a decent job with AF. And it might help to put some more CPU horsepower behind it too, if it's asked to do extra work.
Pentax K-3/645Z/K-1/KP 86k metering sensor
At present the 86k metering sensor only 'see's' a scene via a combined 45x30 matrix of the three RGB colours. This is a big improvement over the old 77 segment metering, and while it may be able to help with scene detection (inc face detection, perhaps) it is not precise enough to take on all the work of auto-focus. The pix below are related and show the limited detail available from the current 86k RGB metering sensor:
But then again, current AF on the K-1, for example, does the job just using 33 (or less, most times) PDAF points, so even a 45x30 matrix could be made to work, as it would be the equivalent of the system using 1350 AF points.
Wow you did a great job rawr.
In the patent they use a 3x3 matrix for each color:
https://ipforce.jp/Kouhou/img?n=0006740666.tif&id=000005&c=B9&t=111813181 https://ipforce.jp/Kouhou/img?n=0006740666.tif&id=000006&c=B9&t=111813181 Here is an explanation of the auto-focus system:
[0026]
When the release button is pressed halfway, the focus is adjusted. The system control circuit 40 executes AF processing based on the pixel signal read from the image sensor 32. That is, the amount of defocus is calculated to shift the image plane to the in-focus position. In addition, AF processing by multipoint ranging can be executed.
[0039]
In order to form a pair of divided images according to the pupil division phase difference method, the focus detection pixel pair PB is formed with light-shielding films SL and SM that block half of the pixels. The light-shielding films SL and SM are formed at positions symmetrical with each other so that a pair of divided images are formed from each focus detection pixel pair.
[0040]
The focus detection pixel pairs PB, PG, and PR are not limited to the configuration in which they are arranged adjacent to each other in the oblique direction, and may be adjacent to each other in the row direction and the column direction. The light-shielding films SL and SM may also be formed at positions according to the arrangement direction of the focus detection pixel pair so that a pair of pupil division images can be obtained.
[0041]
For AF processing by multipoint distance measurement, a plurality of (nine here) divided distance measurement areas are defined for the entire image pickup area IM of the image sensor 32 ( see
FIG. 5 ). When the AF process is performed, the focus detection process is performed based on the focus detection pixel pairs PB, PG, and PR belonging to the divided ranging area in which the target subject is projected.
Multi-point focus will be supported. All this part seems to confirm the end of SAFOX.
might be a 128K sensor (cross our fingers)
PS: Everything translated by google
Reason: images missing
