Closed Thread
Show Printable Version 176 Likes Search this Thread
11-16-2020, 09:05 PM - 1 Like   #166
UncleVanya's Avatar
Fotodiox also makes a version of the same type of adapter. They work a lot like the F 1.7x rear converter (but without the need for the teleconverter since the flange focal distance is shorter.
11-16-2020, 10:28 PM - 1 Like   #167
its a direct copy of TechartPro, you update the firmware on FotoDiox from the Techart website.
11-17-2020, 06:16 AM   #168
bdery's Avatar
QuoteOriginally posted by Mistral75 Quote
The Techart Pro Leica M – Sony E autofocus adapter is a bit different. It does not transcode Pentax autofocus protocols into Sony ones and vice versa. Used in conjunction with a Leica M mount lens or pretty much any SLR lens mounted with a lens mount --> M mount dumb adapter, it make the { lens (+ dumb adapter) + Techart adapter } assembly behave like an E mount autofocus lens. In particular, it includes its own helical and focus motor. Focus is done by increasing and decreasing the thickness of the Techart adapter.
Techart PRO Leica M – Sony E Autofocus Adapter – TECHART Adapters
Think of it as the glassless, motorised, M-E mount equivalent of the smc Pentax-F 1.7x AF Adapter.
Thanks for the explanation. It's a bit convoluted, but it does make some sense (and as a user of that TC I understand what you mean clearly) .
11-19-2020, 09:01 PM   #169
ecostigny's Avatar
Wow, that is certainly a different approach to turning manual focus lenses into autofocus lenses.
11-19-2020, 09:29 PM - 1 Like   #170
mlt
Convoluted is one word. On a 61mp A7r iv, that means keeping 3 different mount surfaces (including one that moves) absolutely parallel to the sensor that also moves for shake reduction. What can go wrong.
11-19-2020, 10:54 PM   #171
QuoteOriginally posted by mlt Quote
Not sure what I'm missing here - it was my understanding the adapter controls focus using the mechanism inside the lens, rather than the adapter itself pumping to achieve focus. So where does the moving mount surface come in?
11-19-2020, 11:24 PM   #172
mlt
The Techart adapter has its own helical and focus motor as stated in Mistral’s post above
11-19-2020, 11:30 PM   #173
FotoPete's Avatar
QuoteOriginally posted by Breakfastographer Quote
The Monster adapter (OP) will have an in-built motor to drive the lens' autofocus. The Techart method is the "adapter itself pumping" to achieve focus, mainly for Leica M as it is manual focus from the start and using other lens mounts is to just piggy-back on that method.
11-20-2020, 12:38 AM   #174
techartpro in action
Advice from the manufacturer is to limit the weight of the attached lens,from memory 700gs(?).
EDIT,680gms is FotoDiox limit.
Some people push the limits though and here is the biggest lens Ive seen on the techart.
11-20-2020, 01:37 AM   #175
Fogel70's Avatar
QuoteOriginally posted by surfar Quote
In this case it should be the weight of camera that is critical, as the lens is attached to a tripod. With the camera moving during AF.
11-20-2020, 03:05 AM   #176
Mistral75's Avatar
QuoteOriginally posted by Fogel70 Quote
Kind of a stretched version of the Contax AX concept.
11-20-2020, 04:10 AM   #177
Its a $ony,they don,t weigh much!
11-20-2020, 04:24 AM   #178
Its a $ony,they dont weigh much!
Aside from the first FF lot which were remarkably light, the newer ones are right on the brink at around 650g including battery and SD card. Add a grip and/or flash/etc. and you might tip the 700g balance they specify.
Unless you're considering the APS-C offerings, which are undoubtedly slim.
11-20-2020, 04:28 AM - 1 Like   #179
QuoteOriginally posted by Benz3ne Quote
Funnily,the FotoDiox which is a direct copy says 680gms I think(trying to jog the memory,there was a lot of discussion a few years ago).
---------- Post added 11-20-20 at 10:49 PM ----------
fotoDiox says 680gms, techart is 700gms
11-20-2020, 06:50 AM   #180
At that point if you grip the body really hard even if the lens is mounted on a tripod you'll probably cause the AF motor to stall.
Closed Thread
a7, adapter, aperture, autofocus, ff, focus, fotodiox, glass, k-mount, kit, lens, lenses, limiteds, moment, pentax, pentax news, pentax rumors, pm, post, price, prices, series, sony, support, tube, video, yesterday
Not using wifi transfer (not good for hundreds of photos to transfer) Penview52 Pentax K-S1 & K-S2 36 10-17-2019 04:04 PM
Adaptadores lentes Pentax k-Sony FE Adapters lenses Pentax k-Sony FE Pentax K2 Pentax Camera and Field Accessories 5 03-27-2019 02:59 AM
All times are GMT -7. The time now is 01:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
