Originally posted by ecostigny
Canon, on the other hand, ditched their FD mount in favor of the all-electronic EF mount when they started introducing autofocus in their film SLRs. The new mount's wider diameter and shorter flange distance, in addition to its different bayonet mount, required an adapter for FD lenses to work on the then-new EF bodies.
Wider diameter, yes: 54mm for the EF mount vs. 48mm for the FD mount.
Shorter flange distance, no: 44mm for the EF mount vs. 42mm for the FD mount.
This is the reason why Canon only proposed a 4-element optical adapter which acted as a low power multiplier (1.26x) for FD telephoto lenses and no conventional adapter without glass, with which the flange of the FD lens would have to be 2mm inside the EOS body.
The 1.26x FD -> EOS adapter had a protruding front element (similar to the current Canon teleconverters), which meant it would only couple with lenses which could accommodate this protrusion.
