Originally posted by Mistral75 where would the GPS antenna be?
I am thinking that the cut-out at the hand grip would be a possible location for the camera's RF (radio frequency) functions, including WiFi, Bluetooth and GPS. About one-quarter of the area at the face of the grip would be required for the self-timer lamp/infrared (IR) remote control receiver, while the remaining volume and area could be used for an integrated RF module, including antennas at the face or along the edges of the opening. These components are relatively small, so I think they'd fit at that location. Embedded GPS patch antennas, for example, can be 18 mm square, but they're somewhat directional. It's also possible to use one multi-band antenna to cover the GPS reception and WiFi/Bluetooth.
The cut-out is larger than seen in the shells of other magnesium-body Pentax cameras, and it's there for a purpose. We also see several screw-down points, which suggests a single assembly or circuit board. A location for RF modules and antennas makes sense to me.
Edit: A possible issue with the relatively large cut-out is the 'flex' that could be introduced at the hand-grip. However, I assume that the rubber-like material that covers the grip will be sufficiently stiff. Some sort of embedded polycarbonate panel or mesh might help to reinforce it.
GPS antennas do not necessarily need a 'skyward' view, but they cannot be shielded totally by metal. Consider a typical smartphone -- the GPS function works quite well regardless of how the phone is oriented.
Of course, I'm not a camera designer and I don't know whether GPS will be integrated. We'll have to wait for more information or the actual launch.
- Craig
