Originally posted by BigMackCam No. When the K-1 is in crop mode, it's no different than an APS-C camera in terms of photographic output (dynamic range and sensor noise aside). If you use the same lens at the same aperture setting on a K-1 in crop mode and a K-3III, the bokeh will look the same. However, the K-3III will produce a higher resolution image from its ~26MP sensor compared to the K-1's ~16MP in crop (which is more-or-less equivalent to a K-5IIs). One potential downside, though, is that the K-3III will be more demanding of lens performance when viewing images at 100% reproduction...
One of the reason that I've been anxious to get my hands on the K3iii is to have a camera which is able to use the resolution which the DFA 150-450 can deliver. It is obviously able to deliver more resolution than the K3 (my current camera) can handle, so I'm not concerned about the performance of that specific lens (or even the HDDA 55-300 PLM which is my next most used lens other than the HDDA 16-85). So I got pretty excited when Pentax claimed to have improved IQ even at low ISO.
I'm going to have to do more research on the benefits of FF for the sake of curiosity. I thought I understood it, but now I'm not sure. For most of the photography I do, I really want the extra effective focal length I get from APSC. For that matter I should drag out the MZ5 and use up the couple of rolls of unused film I still own to see what some of my current lenses look like on a 35mm frame.
Originally posted by Kunzite Not at all. The APS-C crop mode on the K-1 will just give you lower resolution images - but they are essentially APS-C images. Quite similar to what you'd get from a K-5IIs, given the sensor's characteristics. It doesn't even matter if you crop in camera or on your PC. The lens doesn't know nor care...
Sure, I understand that the lens doesn't know or care. I just need to understand better why people fought so hard for a FF sensor aside from the challenges of wide lenses on APSC.
Originally posted by Kunzite I'm not sure about this demanding part; with the same lens, you should get more detail (or at least as much detail, for the worse lenses) on the higher resolution camera. Then, there's hoping for a more precise AF, which might be the largest improvement
The pixels might look worse, but not the image.
Yes, I'm hoping for a more precise AF, but perhaps even the ability to achieve a focus lock faster than with the original K3 on the same lens. Many of the birds I want to photograph are small and move fast, so achieving a lock quickly is critical. One of the reasons I stopped using the DA*300 is that it tends to hunt to minimum focus first, while the DFA 150-450 does the opposite. I thought that I would use the focus limiter a lot on the DFA lens but not so much in practice because it doesn't hunt as much and focuses far faster. The lack of a focus limiter on the DA*300 and its tendency to hunt drove me crazy. I don't know if that default hunt direction is something which could be fixed in firmware.
Optically the lens is amazing but if you can't focus then it's useless. I have the impression that the speed of AF on Pentax lenses is held back by the camera bodies in most cases but perhaps also by the lens firmware in others.
