Show Printable Version 33 Likes Search this Thread
04-29-2021, 01:32 AM   #76
troenaas's Avatar
QuoteOriginally posted by Smolk Quote
The 645 A 35mm is very sharp (I once compared it to several other K 35mms, via the 645>K adapter) but 35mm is not very much for T&S and I don't think there a T&S adapter for it although the flange distance difference would allow for it.
The MIREX 645 to K T&S adapter will do that. I don't know if they are still in business.
04-29-2021, 01:34 AM - 1 Like   #77
troenaas's Avatar
QuoteOriginally posted by Ishpuini Quote
The new body of the K-3 III having less overhang will probably mean I will use the Samyang more than before, because finally I will be able to shift it all the way up, and not have it stop 1 or 2 mm short because it bumps into the top of the camera (as was the case with K-7, K-5, K-3, K-3II).
Wim
You can work around the overhang by turning the camera upside-down.
04-29-2021, 01:42 AM   #78
troenaas's Avatar
Zuiko 24mm f/3.5 SHIFT
This lens can be used on Pentax cameras via a Leitax adapter.
04-29-2021, 01:54 AM   #79
troenaas's Avatar
that is true, but the shift is mostly to preserve perspective, not to get images wider.
I agree, it is mostly for preserving perspective in architectural photography.
But it is also useful when creating panoramic images.
04-29-2021, 11:30 PM   #80
QuoteOriginally posted by troenaas Quote
That's true, but still not very practical. Also rather hard on a tripod.
04-30-2021, 01:51 AM   #81
Good to know. Unfortunately, on eBay they start above $1,000 (apart from one that has damage, although the Japanese seller typically states it as Exc+++++; but at least the damage is described).
04-30-2021, 03:00 AM   #82
troenaas's Avatar
I agree that it is not practical. It isn't hard to turn the camera upside-down on a tripod if you use an L-plate.
04-30-2021, 03:18 AM   #83
35mm shift sounds great. As I mentioned above more normal fl gives very nice shift images if the subject fits. More domestic architecture for instance.
05-01-2021, 02:37 AM   #84
Ah yes, I hadn't considered that. That should work fine with my 3Leggedthing L-plate. I won't need it on the K-3 III, but if ever I need full shift on my IR modded K-3 II I hope I'll remember that tip. tx!
Wim
05-01-2021, 03:57 AM   #85
QuoteOriginally posted by house Quote
Yes, maybe I should try that once. Unfortunately, these T&S adapters appear to be hard to get.
It is of course also a relatively bulky lens, certainly for APS-C, but at 470 g not overly heavy.
05-01-2021, 04:51 AM   #86
I was close to snapping one up that was already adapted to Pentax but of course the listing lasted all of two hours... not surprising considering the guy was selling it for a bit under 200€!
05-01-2021, 05:30 AM   #87
I have the smc Pentax 28mm shift and it's also a bit bulky. I mostly use it when I go to shoot something specific as it's best on a tripod anyway but I wish shift's could come smaller so that you can pack it as a "just in case" lens.
05-01-2021, 06:34 AM   #88
mlt
There’s always the built in sensor shift, granted it is not as much as an actual shift lens, but a small amount could help.
05-01-2021, 07:08 AM   #89
QuoteOriginally posted by mlt Quote
I used that a lot with my K-3 II. Man the K-3II had features made for me! Pixelshift, sensor shift, gps!
There isn't much shift in the sensor though. Just a tiny bit.
05-01-2021, 02:04 PM   #90
thibs's Avatar
How is it optically ?
15mm f/4.5 zero-d, f/4.5, flare, friend, k-1, k-mount, laowa, laowa 15mm f/4.5, lens, mine, optics, optics laowa 15mm, pentax news, pentax rumors, production, shift, venus optics laowa
Laowa 15mm F4.5 Zero-D Shift not in K mount house Photographic Industry and Professionals 11 11-03-2020 08:49 PM
For Sale - Sold: Venus Optics Laowa 15mm F4 1:1 Macro DeepWoodPhotography Sold Items 2 03-11-2018 03:51 PM
Venus Optics Laowa 15mm f/4 Macro Lens for Pentax K yygomez Pentax K-1 & K-1 II 10 07-23-2017 11:38 PM
Venus Optics Laowa 15mm f/4 1:1 macro lens announced WillWeaverRVA Pentax News and Rumors 52 07-29-2015 03:26 AM
All times are GMT -7. The time now is 02:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
