Originally posted by Zygonyx Indeed.
My oriented observation was for the forthcomming comparisons regarding K-3III in the sense that i bet nobody will mention it's compacity advantage over the Nikon.
"Because it's no mirrorless".
We will read it, or not
It will be interesting to see what reviewers say in comparison since the D500 isn't without its own faults...
*Snippet from a D500 review*
In circumstances where there is a clear subject, well isolated from the background, the D500's autofocus and tracking is hugely impressive. Even in circumstances where it only has a fraction of a second to acquire both the subject and focus, it does very well indeed, rendering our bike test irrelevant.
Our test is designed to simulate a subject moving unpredictably at a moderate speed (such as a small child running towards the camera) and this presents no challenge at all for the D500, even when the camera is chattering away at 10 fps.
In this instance, the rider started off too far back for us to be able to specify that the camera should focus on his face, so instead it's focused on his shirt, but the consistency between shots is excellent. We shot the same test multiple times (generating over 700 images) and found we could pick images at random and be supremely confident that they'd be in focus. <--- That sounds like a free pass to me.
Team Sports
Given how well it performed in our standard test, we decided to check just how much of the D5's capability you get in the D500 and made sure we shot a variety of fast-action activities to see what it's capable of.
For skateboarding, BMX and motorsport, 3D Tracking did very well - very quickly acquiring focus on the subject under our AF point and then following it even during burst shooting. However, it's notable that all these events feature a single subject that's fairly distinct from its background, both in terms of depth and color (the two parameters the camera can interpret).
Polo and soccer proved more challenging for 3D Tracking. With multiple similarly-attired subjects we found that, while generally very good, the camera could be distracted too often to be depended on. Even with some adjustment of the 'Blocked Shot Response,' the camera would occasionally wander off and follow a different player if they stepped in front of the intended target. Blocked shot response sounds to me like Pentax's AF Hold which from all my shooting works very very well.
Pros
Excellent image quality: high quality Raw and JPEG
Superlative autofocus performance even at 10 fps
Well-designed ergonomics and handling
4K video quality is generally strong
Joystick makes AF point selection faster
Ability to switch AF point mode with button press really useful
AF Fine Tune process greatly simplified to increase central AF accuracy
Touchscreen implementation fast and effective
Flicker reduction mode gives better consistency under artificial light
Cons
4K video taken from small crop of sensor, limiting lens choice
Snapbridge wireless system is simplistic and (currently) inconsistent
Video tools are somewhat limited
Autofocus in video prone to wobble and re-focus
Quirky battery usage prompts regular use of Airplane mode
Default JPEG noise reduction and sharpening a little high
USB charging would be a useful addition
Overall conclusion
The D500 is one of the most expensive APS-C ILCs currently on the market but its sheer capability demonstrates the continued relevance of the format at this point in the market, even if Nikon seemed a little uncertain about that for a few years. The pixel count and sensor size allow the camera to achieve 10 fps shooting with 1.5x effective extra reach, relative to full frame (albeit at an image quality cost).
Reading that review, it really seems PENTAX was looking at the D500 as a direct target. There was mention of pressing a button and using the control dials to change parameters on the D500 (New Smart Function anyone)? Video Capabilities are pretty much identical (but perhaps the K-3 III won't actually crop the sensor for it).
They do seem to be very similar cameras overall, but the D500 is massive for a crop camera in size and weight. So, ya, it'll be interesting to see if reviews continue the "bash" as per usual, or if they'll actually give the K-3 III a fair objective look/chance.
