Originally posted by house I really find adjusting focus a chore. Paranoid my lenses might be off now...
I did find it a chore. I was using a tilted target, taking images at each adjustment steps, then painstakingly comparing them on the computer, going back to the camera, checking at another focus distance, etc.
Now I've read about the green dot technique and it makes so much sense! I'm actually an optical designer by trade and that's what I do when optimizing values in the lab.à
That technique asks you to set your camera on a tripod at a focal distance close to what you normally do with the lens (a few meters for portraits, for instance). Place a fixed, high-contrast target in front of the camera. Focus using live view (or manually). Then disable AF, half-press the shutter and go through the correction values (-10 to +10), nothing which values let the green dot light up to confirm AF. Let's say you get a green dot from +3 to +7, it means the optimum is likely in the middle, so +5.
And done.
