04-15-2021, 08:03 PM   #61
UncleVanya's Avatar
I’m going to do this to my k-3 and KP this weekend.
04-15-2021, 08:09 PM   #62
FA31 focus seemed more decisive after the firmware update, but that could just be psychophotography.
04-15-2021, 08:21 PM - 1 Like   #63
No, it says for all the FA limiteds, at least how I interpret it:
"Optimized focus operation for new lenses HD PENTAX-FA 31 mm F1.8 Limited, HD PENTAX-FA 43 mm F1.9 Limited, HD PENTAX-FA 77 mm F1.8 Limited lenses and smc PENTAX-FA 31mm F1.8AL limited, smc PENTAX-FA 43mm F1.9AL limited and smc PENTAX-FA 77mm F1.8AL limited lenses."
04-15-2021, 08:25 PM   #64
Class A's Avatar
QuoteOriginally posted by leekil Quote
"... and smc PENTAX-FA 31mm F1.8AL limited, smc PENTAX-FA 43mm F1.9AL limited and smc PENTAX-FA 77mm F1.8AL limited lenses."
Ah, thanks!
I didn't catch that part.
04-15-2021, 09:34 PM - 2 Likes   #65
Belcik's Avatar
QuoteOriginally posted by FozzFoster Quote
Looks like many cameras are getting a firmware update available on April 15 2021 which includes:
RICOH IMAGING
PENTAX K-1 FIRMWARE UPDATE VERSION (1.54)
PENTAX K-1 Mark II FIRMWARE UPDATE VERSION (1.20)
PENTAX KP FIRMWARE UPDATE VERSION (1.30)
PENTAX K-70 FIRMWARE UPDATE VERSION (1.12)
PENTAX K-3 II FIRMWARE UPDATE VERSION (1.11)
PENTAX K-3 FIRMWARE UPDATE VERSION (1.42)
I wonder if we will see the K-3 III firmware added soon too.
Will do that only for the last two lenses
04-15-2021, 10:34 PM - 1 Like   #66
Nakedgun's Avatar
RICOH IMAGING
Many thanks!
Done & done.
04-16-2021, 12:54 AM   #67
RobSpain's Avatar
QuoteOriginally posted by Mistral75 Quote
Concerning the K-70, there is also a bug fix:
Thanks for that!
I've now just updated my K-70 with the latest firmware. No noticeable differences but everything seems to work ok!
04-16-2021, 01:08 AM   #68
Andrea K's Avatar
who knows what is the improvement with the "old" smc and why there was something to improve..
04-16-2021, 01:37 AM   #69
wiseman's Avatar
Using the camera SD card for firmware update
I had to connect my KP to my PC with a USB cable to copy the update file onto the SD card. The firmware update performed correctly.
My question is whether anyone was able to copy the update fine onto the SD card by inserting the card into a PC or laptop. My PC and laptop (both windows 10) would not copy the file onto the SD card stating that the card was write protected. Yes, the slider on the SD card was in the unlock position.
Anyhow, I did get my camera updated, but I would like to know why the SD card seems to only be writable while in the camera.
Thanks for any help!
04-16-2021, 01:38 AM - 1 Like   #70
QuoteOriginally posted by Andrea K Quote
I do not own any of three amigos at the moment, but I've test shoot some of my lenses on lensalign target- and on K-1II I've found two things that are intriguing me- Sigma 85 EX DG now works flawlessly on zeroed micro adjustment, previously it was set to +4 for optimal results with this test setup, Pentax HD FA 35/2 while not needing any microadjutment, and had tendency to get a bit overfocus, and then go back (extremely fast, so not a problem, I had both SMC and HD, and both worked that way)- now it drives straight to spot on in one run no matter of focusing direction without going back.
@banangrg tested his SMC Limiteds on KP, maybe he noticed something more
04-16-2021, 02:02 AM   #71
bxf
bxf's Avatar
QuoteOriginally posted by wiseman Quote
I keep notes of some of my activities and experience with my laptop. One of my notes is this:
If Windows says SD card is write-protected when it is not, move the Lock switch on the card part way between Lock and Unlock.
04-16-2021, 02:07 AM - 1 Like   #72
QuoteOriginally posted by Reed Quote
As the Ricoh mentioned, the focusing algorithm has been optimized while using these lenses (also SMC ones).
I have tested all lenses in the late evening, in dim lit room (ISO 1000-1600, SS about 1/100, lenses wide open).
Before the update, the 31 was the least accurrate - while now there's a big improvement on KP. 77 and 43 seem to work better too.
Even the old FA* 85 seem less quirky in it's focusing, but it's not as big change as in case of the FA Limited trio.
50-135 works nicer and more precise during focusing without a "half-stops" (some micro readjustments before final "locking" on the target) as it happened before.
04-16-2021, 02:31 AM   #73
This is tricky business to evaluate. I should have held back from upgrading to do before after tests.
04-16-2021, 03:36 AM   #74
I have k70 and FA 31, I have no problems, why should I do this?
04-16-2021, 03:42 AM - 3 Likes   #75
QuoteOriginally posted by nonpigliounoshoot Quote
Behind every firmware release notes stated for public, there is also way more things fixed in the background that are not publicized. Consider firmware updates as a basic tool maintenance that should be done just in case.
645d, 645d image transmitter, af, af fine adjustment, camera, command, firmware, focus, hd, image, kp, lens, method, pentax, pentax news, pentax rumors, pentax-fa, post, screw, smc, software, system, transmitter
Ricoh GR III Firmware v1.41 Released kvoz123 Ricoh GR 15 04-28-2021 03:20 AM
Pentax K-1 Firmware v1.53 Released PF Staff Homepage & Official Pentax News 4 06-21-2020 09:44 PM
New firmware 1.10 for K-1 released funktionsfrei Pentax K-1 & K-1 II 2 05-19-2016 10:55 AM
New NEX Firmware released 7, 6, 5R, 5N, F3 nosnoop Canon, Nikon, Sony, and Other Camera Brands 3 02-06-2013 11:29 AM
New K-5 firmware to be released ? Xatnep_CJ Pentax K-r 2 01-05-2011 11:02 AM
All times are GMT -7. The time now is 01:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
