06-06-2021, 07:28 PM - 3 Likes   #1
K-3 Mark III firmware V1.02 now available.
New release of firmware at Support | RICOH IMAGING
Cheers,
Terry
06-06-2021, 07:47 PM   #2
sbc
Thanks for the info. Flash comp problem on S.Fn dial still not fixed.
06-06-2021, 08:04 PM   #3
Larrymc's Avatar
QuoteOriginally posted by tduell Quote
Cheers,
Terry
Thanks for the heads up!
06-06-2021, 08:27 PM - 3 Likes   #4
Custom User Title
FozzFoster's Avatar
might help someone here:
06-06-2021, 09:54 PM   #5
Paul the Sunman's Avatar
Done. Seems to have been a very minor bug fix.
06-07-2021, 02:18 AM - 2 Likes   #6
Not a Number's Avatar
Direct link to K-3iii download page:
Latest PENTAX K-3 Mark III Firmware Update : Software Downloads | RICOH IMAGING
Changes to V1.02
  • Improved – When using both SD card slot 1 and slot 2 at the same time, operation becomes unstable in rare cases when using some SD cards.
  • Improved stability for general performance.
06-07-2021, 04:01 AM   #7
Seeker of Knowledge
aslyfox's Avatar
" easy peasy "
" can of corn "
no problem at all
06-07-2021, 10:39 AM   #8
Painter's Avatar
Personally I’m going to wait for a firmware update that I can notice. The risk of something happening when doing a firmware update is not 0 so I don’t want to be doing it more than I need to. I will need to put some thought into what I would tip me over the update edge but undefined general stability is not it.
06-07-2021, 10:44 AM - 2 Likes   #9
Custom User Title
FozzFoster's Avatar
QuoteOriginally posted by Painter Quote
The risk of missing a once-in-a-lifetime shot because of a preventable random system glitch is also not 0 :P
06-07-2021, 12:09 PM   #10
Kobayashi.K's Avatar
QuoteOriginally posted by FozzFoster Quote
A glitch that is random is unpreventable by its nature. So a 'preventable random system glitch' doesn't even exist. A far more plausible scenario is that persons who are afraid of disasters happening during a firmware update are attracting glitches simply because they have not the right mental attitude. For example they forget to charge the battery before an update, and the camera is bricked when it runs low (and they say "I knew something would happen"). So, the best advise is indeed to wait with an update until you are convinced it will work.
06-07-2021, 12:12 PM - 2 Likes   #11
Wheatfield's Avatar
QuoteOriginally posted by Kobayashi.K Quote
There's nothing like being controlled by fear.
06-07-2021, 12:20 PM - 2 Likes   #12
reh321's Avatar
Something that seems 'random' to us may be entirely explainable to the developers.
From experience I can say that a 'preventable random glitch' really does exist - I have personally created - and fixed - many of them.
I get concerned only when I see many reports of fixing them long after the product has been released.
06-07-2021, 12:40 PM   #13
QuoteOriginally posted by reh321 Quote
From experience I can say that a 'preventable random glitch' really does exist - I have personally created - and fixed - many of them. I get concerned only when I see many reports of fixing them long after the product has been released.
In physics an event is random or it is not random. There is no state between those two possibilities. So, as I explained a 'preventable random system glitch' is a contradictio in terminis. I think we are too much accustomed to 'random' processes (in software) that are artificially created and actually semi-random. It is not possible to create a true random process with software. True random signal generators are always using a physical process, for example thermal activity from ions, or particles that are emitted from a radioactive material.
Going back to the subject, a matter of more concern is the reliability of the new firmware itself, because in the past it has often happened that within one or two days Pentax published yet another update to compensate for new errors. So that is a valid reason to delay installing the new firmware.
06-07-2021, 01:16 PM - 2 Likes   #14
Can be seemingly random when the cause-effect relationships aren't known. Once underlying variable is known as a cause, all of the sudden , what seemed to be unpredictable becomes predictable, not random anymore.
06-07-2021, 01:38 PM - 2 Likes   #15
You're going too far - people usually don't mean that when they say random. They usually means "it doesn't always happen, and I didn't see an extremely obvious pattern".
OTOH, I'd say that a 'glitch' involving a cryptographic strength pseudo-random number generator would do the trick (can you differentiate from it and true randomness?). Been there, done that. The behavior was completely deterministic, the trigger was for all practical purposes random.
firmware, iii firmware v1.02, k-3 mark iii, mark iii firmware, pentax news, pentax rumors
K-3 BULB MODE issues on Firmware V1.11 V1.20 V1.40 gedasst Pentax K-3 & K-3 II 8 01-16-2019 02:04 AM
[URGENT] is Firmware V1.02 necessary from V1 for k-50? Any major help? Hexism Pentax K-30 & K-50 9 12-20-2014 08:51 PM
Firmware v1.03 now available Rob22315 Pentax K-01 26 05-04-2013 06:11 AM
New firmware: v1.13 for K-5/645D, v.1.12 for K-7/K-r, v1.03 for K-x Adam Pentax News and Rumors 71 05-15-2012 01:42 PM
Comparison of K-5 low light focus accuracy with v1.01 and v1.03 of firmware tram57 Pentax K-5 & K-5 II 3 03-20-2011 08:13 PM
All times are GMT -7. The time now is 03:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
