Originally posted by frogger I agree, I don't see whats the big deal. Its as if people think by adding video they will skimp on improving other areas.
Video means a different, or at least differently optimized, write-to-card output pipeline; HD video is a very different critter from a raw image. (or it means distinct pipelines and greater complexity and thus expense.) It means greater emphasis on the LCD display, and a sensor choice biased toward a sensor which can hack an hour of continuous exposed use in bright sunlight versus one that maxes out at a couple of seconds, so it's a use/sensitivity tradeoff of some kind.
Me, I'd almost rather the LCD display wasn't there, driving a trend away from the optical viewfinder. (which is precision glass, rather than consumer electronics; cost consciousness will tend to bias towards the LCD.)
I'd much rather the settings info -- which is unquestionably useful -- was available via a fully-switch-offable projection into the viewfinder mechanism; I'd expect they could do that through one of the sides of the pentaprism, these days.
