Originally posted by Rondec I thought the whole point of the numerous examples was simply to provide protection from other brands using the same optical formula in a lens. Often some of the examples are unlikely to happen -- they require a shorter registration distance or have really odd aperture/focal length combinations.
Both may happen. Every patent has degrees of preferred embodiments, and examples that you use to widen the area around the patent stopping others from getting too close. You use the specification to publish what you don't want others to patent and the claims to stop others from making similar products. Of course the scope of the latter will often decrease during the prosecution, maybe ending up with the preferred embodiment while the surround area is maintained.
If your patent also covers embodiments that you don't intend to use you can licence them to someone else, possibly trading patents.
If you find a solution that, for example, can simplify internal focussing for a certain type of lenses of course you may want to use that several lenses. The examples in the patent are not limiting, you may choose to use patented solution in lenses that have not been suggest. You may even for strategic reasons omit mentioning a lens that you intend to produce.
This is why I don't really consider patents as a prediction of future lenses.
---------- Post added 22-09-22 at 14:01 ----------
Just for fun, here's a machine translation of the independent claim. Sadly, thay have not applied for a patent outside Japan, which could indicate a low interest in the idea. It seems that the most important aspect of the patent application is how they move two focussing lens groups. I think this can be used in many different lenses.
[Claim 1]
Sequentially from the object side, comprise an object side lens group, an aperture
diaphragm, and an image side lens group, and, [ an object side lens group ]
Sequentially from the object side, have the 1st lens group of the object side, and
the 2nd lens group of the object side, and, [ an image side lens group ] Sequentially
from the object side, the *** 1 lens group of positive refracting power, and the
image side intermediate lens group, Comprise an image side last lens group and the
variable power from a short focal length end to a long focal length end is faced, The
interval of the 1st lens group of the object side, and the 2nd lens group of the
object side, the interval of *** 1 lens group and the image side intermediate lens
group, And the interval of the image side intermediate lens group and the image side
last lens group changes, and, [ at least one copy of the 2nd lens group of the object
side ] Have the object side focussing-lens group which moves to optical axis
direction at the time of the focus to a short distance from infinite distance, and, [
at least one copy of the image side intermediate lens group ] The variable power
optical system characterized by what it has the image side focussing-lens group which
moves to optical axis direction at the time of the focus to a short distance from
infinite distance, and the object side focussing-lens group and the image side
focussing-lens group move to optical axis direction by each other different locus at
the time of the focus to a short distance from infinite distance.
