Originally posted by Fogel70 Technically a battery with higher capacity capacity do not necessarily need a new charger, but the new battery would need to be mechanically and electrically compatible with the charger. So it limits how the battery can be modified.
With a higher capacity the battery would take longer to charge. I believe it would also be possible to make a D-LI90 with higher capacity without changing the size of the battery (increase maybe 20-25%). But the Pentax D-LI90 is already quite high in capacity. It has almost twice the capacity than the Sony NP-FW50 I have for my mirrorless cameras. Pentax D-LI90 has about the same capacity as batteries on other brand of high end ILC. They are usually around 15Wh, and D-LI90 is 14Wh.
So it may be a better power management Pentax cameras need.
Nowadays slightly larger charging current should be possible without much drawback; there's no need to go to the ridiculous 65 W charging my phone has. Even then, if we just keep the current "fast charger speed", to have 2 hours charge time instead of 1.5h or so*, I'd be happy to take the extra half hour if that gives us 25% more juice on the field. I know that Pentax cameras will always drain more power than comparable DSLRs from other brands, due to the extra current draw from the IBIS, and I'm okay with that, I don't mind lower battery life - but not to the extent where I run two batteries** dry in the time my mate's Nikons and Canons aren't even done with the first. Any improvement there would be beneficial.
For example, the current Nikon EN-EL15C and Sony NP-FZ100 batteries (in use in their FF mirrorless cameras) are a bit higher nowadays, at 16 and 16.4 Wh, calculated (against the 13.4 of the Pentax, calculated the same way - not sure why they write 14 Wh). I agree that the enclosure of the D-Li90 wouldn't really let them improve capacity, but a 20% improvement would be welcome.
A 645Z with IBIS would probably need a higher voltage - the Canon 1D series runs 11V instead of the typical 7 as well - so I suppose if we see a new high-end battery it will be there or with the proverbial K-1iii (though the K-1iii technically wouldn't
need it, it would be very appreciated
*Well, compared to the evening my current charger takes, everything is fast
**Both Pentax-branded.
