Originally posted by luftfluss
A sharp lens coupled with a good TC will still give you a resolution advantage compared with cropping, even taking into account having to using a higher ISO to counter the loss of light.
I have 1.5x SHQ Kenko, 2x Kenko and 1.7x Pentax AF TC
Results depend highly on lens that is attached. In general 1.5x teleconverter works very well with most lenses. It looses only a bit of light and with lenses like 100/2.8, 70-200/2.8 or 100-300/4 it provides results that are significantly better than crops. Even on 24Mpix K3. If lens has hi-res central part of image, it can even improve overall image. An example - DA18-135 is known to have weaker borders. And if you attach 1.5x TC on it, it magnifies central part that is sharp and crops borders. Results are very good.
But surprisingly even lens like Sigma 50-500 benefits from this TC, it slows down AF a bit, but AF accuracy is better.
2x TC is weaker and I'm using it mostly with tripod. It can AF with most fast lenses, that is no problem. On K3 even Sigma 18-250/3.5-6.3 OS works with this TC and even stabiliser in that lens behaves very well, but it needs light because it is 500mm with F12 equivallent aperture when open and towards F16 for better results, and it also needs at least 1/320s or 1/500s to be sure.
1.7x AF TC from Pentax is somewhere in the middle. But concerning image quality, for some old lenses this adaptor can in fact improve image output significantly, because old lenses tend to have weak multicoating or no multicoating applied at last elements. It was not that important for film. But shiny sensors of digital cameras reflect a lot of light back. And exactly in this case, this adaptor works as additional SMC coated back module for those lenses, which results in improved contrast. And contrast + resolution gives you "sharpness".
