Originally posted by reh321 I had a 18-250mm lens once for my Canon Rebel, but I had retired it before I came back to Pentax in 2015. Even before I had mounted it, I knew which other lens {28-80mm - later 18-55mm } or {70-300mm} I would use instead, and I seldom would switch between them, so why ‘bother’?
The way I came to the super zoom was this.
From the mid 80s to about 2000. I had a manual focus 28-80 or 85 zoom by Vivitar, and a no-name 70-210 and they covered all my needs. About 2000 I could see digital was coming and if I got a pentax DSLR I'd want auto focus, and bought an Mz5n + Pentax 28-105 zoom (
FA 28-105/4-5.6 [IF] | The K-Mount Page ) and a Sigma 100-300 zoom. The sigma was a particularly cheap and nasty lens, and the two Sigmas I've had since were 10 times better. Then I got the *ist-D with the 18-35 FAJ lens. (
FAJ 18-35/4-5.6 AL | The K-Mount Page) Plasticky and not hugely satisfying.
35mm was too short on the 18-35 so I kept needing to remove it to get the mid range of the 28-105. But on that 28 wasn't wide with the crop sensor, and lots of shots were taken at 105 when I wanted a bit longer but wouldn't put the sigma on. I also travelled a lot and wanted to take the camera but I needed at least two if not all three of the zooms and that was a pain. So the Pentax 18-250 solved the problems of carrying 3 - it is the same size as the biggest of three. Optically it was no worse than the two Pentaxes and better than the Sigma, and at any given focal length it had the same maximum aperture as the lens it replaced. It only went to 250mm instead of 300, but the truth was if 250 wasn't enough most of the time 300 wasn't either.
Any argument that such-and-such a zoom was better was instantly countered with "but then I'd need to carry two zooms all the time". (I did end up with a second zoom for super wide tasks, but I only carried it some of the time).
I didn't want to have a long zoom and short zoom for the K1 so I bought the nearest FF equivalent I could - a 28-300 Tamron from c. 2000. It's a very usable lens. If I can pick a prime I'll use a prime instead, but when I can't the Tamron does fine.
