Originally posted by pres589 If this leaves the 21's as the widest primes available, on a crop system that seems less that optimal, in the extreme. I know there's a couple zooms that cover this focal range but I always felt like the DA 15 was a pretty special package.
Will refrain from commenting further as I don't think we have a clear picture of the situation with this lens.
It's only the silver version of the DA 15 Ltd that has any question about it, and even then it is a bit dubious. There was a post on a Japanese rumour site last year that suggested the silver version is discontinued. However, in the following months you would expect the number of retailers selling that model to reduce pretty quickly, but that has not really happened. In contrast, for the other lenses mentioned in this thread, you can absolutely see the availability dropping fast (See my note below if you want to know how to check this).
Having said that, some retailers marked the silver version as out of production and Pentax has moved the lens to its outlet store. So it might be on its way out.
My theory is that Pentax is going to stop offering this generation of the DA Limiteds in silver, as they did with the last generation. It's just a matter of the 15mm selling through fastest. It is in fact quite normal for Pentax to offer silver versions of lenses and bodies for a limited time.
So I don't think you need to worry about the 21mm being the widest prime.
Note for people with too much time on their hands: If you want to see how many retailers are still selling a Pentax lens, you can look at the list of Pentax lenses on the comparison site kakaku.com. Note that this is not all shops in the country but it covers quite a lot, including two of Pentax's own stores on Yahoo Shopping and Rakuten.
https://kakaku.com/camera/camera-lens/itemlist.aspx?pdf_ma=251
The second column with the price in red text is the price for a new item, and you can see something like(全30店舗), which means the lens is available in 30 stores. This is updated daily. A Pentax K-mount lens is typically available in between 20 and 35 stores. So after we see some sign that a lens is discontinued, such as the availability on a store's website or a tweet from a store owner, and assuming that information is legitimate, it will normally go below 20 pretty quickly. This is what I look at to tell if there is something to the rumour. The DA 15mm in silver is still available at 21 stores many months later, which is quite normal and about the same as the other silver limiteds.
The third column with the price in black is for used items, and this is why you'll see items in the list that were discontinued some time ago and have no new stock.
