Originally posted by Henrico When you compare the difference between the old and new DFA 100 macro you can see only one single element is replaced by a similar sized doublet. So the barrel and all the other elements remained unchanged. And the coating is replaced by HD.
Clever engineering by Ricoh, similar like bringing out the new KF.
What you are glossing over is that introducing a new element
is changing the optical formula. It's very unlikely that introducing a new lens element wouldn't require reworking every element in the lens.
When I bought the new 100 macro I compared it directly to the previous one in an optical torture test environment. The new one shows far less fringing and more edge sharpness, though the 36mp sensor on the K1 is barely high res enough to show it.
It may look like the old lens, but it's a new design where it matters and bodes well for the introduction of a higher pixel count K1 replacement. For the most part, the old lens was fine on the K1, but toss a higher resolution sensor in front of it and it might show it's age.
Hopefully they will do something similar with the new 50mm lenses as well. If they want that lens to perform as expected on a higher resolution K1, the optical formula will need to be updated. Actually, if they had wanted it to perform as expected on any digital camera it should have been updated in 2006, but instead they came out with the DA* 55/1.4 in 2008 and the very expen$ive DFA*50/1.4 in 2017, and left the FA lens to languish.
The FA 50/1.4's optical design dates back to 1984. It hasn't changed in nearly four decades, and it shows.
I expect Ricoh changed the name on the K70 to try to get away from the solenoid failure stigma attached to that camera. It's not a 100% new camera, but it's new where it counts and is in keeping with other manufacturers putting fresh lipstick on their pigs and selling them as the next earth shattering product.
