I don't think you should cut aperture speed in half to compenste for 2x crop sensor found in G-1
As far as DA on anything other than pentax you're right, no aperture control except for DA 50 macro and DA 100 macro. Just another reason why I like older adjustable aperture ring glass. And why I assume lenses like FA 77mm 1.8 Limited will be discontinued in favor of 70mm DA. Only other DA limiteds will survive over close focal length FA counterparts. Recently issued 35mm DA Limited macro is like this too:
No aperture ring at lensmount ;^(
I doubt we'll ever see a new design pentax lens with adjustable aperture ring at lens mount. I like adapting lenses, primarily to eos full frame dslr mount. If I owned an aps-c eos I could use all my older pentax lenses without aperture lever interference as I already own half dozen PK to Eos mount adapters. But with a K20D inhand that aps-c eos like 50D is a pointless purchase. On 5D I cannot use pentax lenses due to aperture lever interference with mirror and I am not going to remove or cut off levers to experiment.
Anyways, G-1 looks intersting, but so does D700.
Originally posted by Douglas_of_Sweden Some problems:
With a k-mount-Olympus 4/3 adapter I would loose autofocus and only be able to shoot wide open since the adapter only allows completely manual exposure at the mechanically set aperture, and since the DA40 has no aperture ring...
Lets say I go Olympus 4/3 fully...yes the body is thin, but they have only one lens that is thin enough to use this advantage, the 25/2.8 pancake, a lens which correspond to a 50mm/5.6 on 35mm film or 37.5/4.2 on APS-C. Do I want such a slow lens anyway? It makes the Pentax pancakes look fast. And Pentax has three DA pancakes + the FA50 which would also be thin enough.
So while considering if the DA40 on my *istDS (which is 1.5mm thinner than the K-m) would be small enough, I keep using my MX and Super-A bodies with smallish 28 and 55mm lenses as my pocket SLRs, and with this I'm getting more functionality on these old bodies than these lenses would have on a 4/3 olympus with adapter.
Yet would like to see that Pentax DSLR that goes thinner than the K-m and *istDS. Is it possible or is the thickness of the APS-C sensor the limiting factor? Is the 66-67.5mm of the *istDS and the K-m the thinnes possible? Anyone who knows?
