Originally posted by Dartmoor Dave I was really thinking about putting an FF sensor inside a smaller body, rather than an APS-C sensor inside a bigger body. Remember the M series film SLRs? Why couldn't a full frame sensor fit inside a body the same size as a K3?
Originally posted by Fogel70 If you want AF and IBIS in a FF body it require a larger body than K3. At least if using the current IBIS design used for Pentax DSLRs. K1 is still quite small for a FF DSLR.
Since I still have my MG and ME-Super .... behind the image plane sits the sensor, IBIS assembly, the system board which has various sockets on the left as you through the VF, and more sockets and the SD on the right, then the display, where the film take up was is where the battery sits. There are also more components to cock the shutter instead of doing from the thumb lever. A K1 spec camera could probably be a little smaller The prism is bigger than an APS-C camera, the mirror box is fixed size - with a sensor that doesn't fill the back of the box, the unused space can be used to accommodate the SR platform. Not only that space used by the sensor in a FF camera but the SR bits need to be more powerful to shift a heavier sensor, So the APS-C camera can always be a little smaller than FF. I doubt that AF makes a difference though, since the K1 only has an APS-C AF mechanism not a FF one.
