10-31-2023, 07:47 PM - 3 Likes   #1
K-3 Mark III firmware update
Changes from V2.10 to V2.11
Improved stability for general performance.
* When this update is done, the contents of version 2.10 and earlier will be also updated.
* When this update is done, you will not be able to restore back to version 2.10 or earlier.
See Support | RICOH IMAGING
Cheers,
Terry
10-31-2023, 10:51 PM - 1 Like   #2
I have experienced some trouble with the HD DA*16-50/2.8 PLM since firmware 2.10 so I really hope it is those problems that is fixed :-)
11-01-2023, 12:50 AM - 1 Like   #3
Yaki's Avatar
QuoteOriginally posted by StigVidar Quote
I hope you will share your experience with the last update and the HD DA*16-50/2.8 PLM. Thanks.
11-01-2023, 02:50 AM   #4
sbc
Updated! Although I have zero idea what it does.
11-01-2023, 10:26 AM   #5
ramseybuckeye's Avatar
QuoteOriginally posted by tduell Quote
Cheers,
Terry
Thanks for the heads up!
Since the last update was not very long ago, I would suspect that would be part of it. I don't have the lens, but hopefully it does fix it.
11-01-2023, 10:58 AM   #6
Larrymc's Avatar
What was the specific problem you were having with the16-50?
11-01-2023, 12:12 PM   #7
QuoteOriginally posted by Larrymc Quote
The problem is that the the focus is changing a lot from infinity to nearest focus and back to infinity again when I am zooming. It mostly change focus around 35mm. But it doesn't always do this. And never with a K50. This has recently started and it is still happening with 2.11.
11-01-2023, 04:34 PM   #8
I keep hoping that one of these updates will allow the DA560 to use all of the focus points. Oh well, maybe the next one...
11-01-2023, 07:03 PM   #9
Larrymc's Avatar
Strange behavior, mine doesn't do that. The focus issue I was having has been cleared up with the 2.11 firmware update.
11-02-2023, 01:23 PM   #10
Yaki's Avatar
I am with 1.8 still and I think to wait unstill the next update. I Don't want ho have problems with 16 -50 PLM since it is my main lens.
11-06-2023, 01:59 PM   #11
QuoteOriginally posted by tmlawes Quote
What did you mean ( all focus points ) ?
11-06-2023, 05:22 PM - 2 Likes   #12
Kobie's Avatar
QuoteOriginally posted by nixxo2002 Quote
It doesn't allow the edge points to be used. The K-3 III goes into "AF Restriction" mode which only allows the 65 AF points in the large center grid to be used.
11-06-2023, 05:24 PM - 1 Like   #13
There is a list on page 117 of the user manual detailing which lenses have autofocus point restrictions on the K3-III. The DA560 is one of them.
11-06-2023, 05:50 PM   #14
QuoteOriginally posted by Kobie Quote
good to know , i shoot a lot da 560 with k3 iii , and i eliminated edge af points from beginning .that why i never knew about this issue .
thanks
11-06-2023, 05:51 PM   #15
thank you
af, button, camera, change, focus, k-3 mark iii, lens, lot, mark iii firmware, pentax news, pentax rumors, update, version
Master your Pentax K-3 Mark III with the Pentax K-3 III eBook Adam Pentax K-3 III 44 2 Days Ago 06:10 PM
K-3 Mark III Monochrome firmware update. Mack53 Pentax K-3 III Monochrome 2 09-08-2023 02:07 AM
K-3 mark III and K-1 II firmare update to 2.31 tduell Pentax News and Rumors 13 08-03-2023 12:49 PM
Does the K1 Mark II still make sense to buy today? Is there an Mark III in the works? davidphoto Pentax Full Frame 161 07-18-2023 03:32 PM
All times are GMT -7. The time now is 06:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
