03-24-2009, 06:25 AM   #31
QuoteOriginally posted by creampuff Quote
Dump that stupid crystal ball.
This is what's coming... so everyone stop complaining and start saving up.
Very nice!!
As for saving up... I'll start doing that if this camera doesn't cost more than my car (€6000) other wise... I'll just watch the lucky few take beautiful pictures with it
I was waiting for some more concrete infos (price, sensor...) but I guess I can wait one more year...
03-24-2009, 06:32 AM   #32
What? No one is screaming for faster shutter speeds?
This definitely should make the fashion photog and wedding industry take notice...a weathersealed MF camera? Wow. Now I just need a bailout so I can load up on MF gear
03-24-2009, 06:40 AM   #33
Digitalis's Avatar
they have made some improvements since they last exhibited the digital 645.
this is the version I got to handle, and the ergonomics were top notch...the viewfinder needed a bit of work to live up to the standard the original Pentax 645NII set...I hope they have remedied that.
03-24-2009, 09:34 AM   #34
ogl
ogl's Avatar
What are these buttons?
03-24-2009, 09:36 AM   #35
ogl
ogl's Avatar
I'm impressed by new design of 645D. Very good. Original switch of AF mode.
ISO button.
03-24-2009, 11:24 AM   #36
I'm in total agreement with Digtalis when he states:
Hasselblad marketing…….saying that a 48mm square digital sensor was full frame when it was anything BUT full frame on medium format ?
Regrettably Hasselblad are not the only culprits in this respect and with the passing of time, I find myself becoming evermore irritated with reviewers and advertisers who continually keep referring to larger digital cameras with cropped-sensors as Medium Format….which they are categorically NOT !
However much the marketing types might keep attempting to move the goalposts in this respect, a 36 x 44mm sensor ain't MF whichever way you cut it…….period !
The primary reason for my frustration is that I still own a number of fabulous Mamiya MF lenses including a treasured Mamiya Shift C 50mm f/4 which I am dying to use in conjunction with a genuine 60mm x 45mm-sensored digital body…..so near and yet so far……ggrrrrrrr !!!
Best regards
Richard
03-24-2009, 11:28 AM   #37
thibs's Avatar
QuoteOriginally posted by Confused Quote
Best regards
Richard
Mmm youmight want to explain the reasoning, I'm lost.
BTW, 645 format is NOT 6x4,5 centimeters. You might want to check your facts.:ugh:
03-24-2009, 11:45 AM   #38
AndrewG NY's Avatar
I was thinking maybe that button below the review/preview LCD *could* be for live view or digital preview.
The two black buttons are for power zoom. (OK, probably not.)
03-24-2009, 11:45 AM   #39
Did a quick dig on what's available out there and crop factors:
full frame medium format size: 50.7x39mm (only the Phase One back AFAIK)
Mamiya 645zdb: 36 x 48mm (roughly 1.2?)
Leica S2: 30 x 45 mm (roughly 1.3)
Hassy-31: 33 x 44mm (roughly 1.3)
Hassy-39 & 50: 37 x 49mm (roughly 1.1)
Pentax 645D: 36 x 44mm (roughly 1.3)
And nearly everything is 1-1.2 Frames/sec...Canon 1DmkIII users don't have to be worried
03-24-2009, 12:18 PM   #40
Hi again thibs
According to the infallible Wikipedia, the most common aspect ratios are 6×6*cm (square) and 6×4.5*cm (rectangular). The last time I checked, 6cm = 60mm, 4.5*cm= 45mm ?
As for your puzzlement:
Mmm you might want to explain the reasoning, I'm lost.
O.K. You might like to try out an interesting experiment should the opportunity ever arise. Simply attach a Mamiya Shift C 50mm f/4 lens to any of Mamiya's current range of so-called MF digital bodies and see what happens. A sizable portion of both the top & side coverage seen through the viewfinder fails to fully materialise on the final image is what happens !!! I should know because I tried this procedure in abject futility once myself in a well-known London photographic store. Considering that dealerships are reputed to be charging somewhere in the region of approx $20,000.00 for Mamiya's new DL33, I'm afraid I remain distinctly under-whelmed by this latest announcement.
Best regards
Richard
03-24-2009, 12:29 PM   #41
56x41mm image size on "60x45" 645N format
I thought 645 meant 60x45 too. Weird, I wonder why Pentax called it 645 instead of the correct 564? Same numbers different sequence.
In fact its easy to find this same mistake on numerous websites I just googled up. Heres one with 645N specs thay say image size is 56x41. 31mp kodak sensor is 48x36 so plug this into your crop factor computer please? While doing this plug in full frame 24x36 too? Just curious how a full frame canon with K-645 adapter mounted on a 5D crops out too. Thanks Ken.
FOTO VIDEO - SHOP - Pentax 645 NII <BR>
QuoteOriginally posted by kenyee Quote
03-24-2009, 12:29 PM   #42
gazonk's Avatar
Hi again thibs
Image size: 56mm x 41.5mm according to 645NII : Medium-Format Cameras : PENTAX
03-24-2009, 12:34 PM   #43
kibipod's Avatar
Drool drool drool for the better part of the day......................
I have a full blown case of CBA (camera buying addiction) and no cure in sight.
Now, few questions need to be answered - 1) do I need one? No. 2) do I want one? Yes yes yes. 3) am I a pro or am I going to print big? No. 4) so what am I going to do with this camera? I don't know. I will show it to those canikonites and make them so jealous. Also, I assume that by just acquiring a MF digi, I will be a better photographer.
So far so good. Only one question remains. How am I going to afford this? Hey, is anyone interested in a kidney?
Or the alternate option is opening a "give subho a digi MF for his birthday fund". People, fellow pentaxians......please donate generously. Your help is very very appreciated.
Cheers........
Subho
03-24-2009, 12:40 PM   #44
645 is just an aspect ratio, not the actual image size. It's more intuitive than calling it 5641 format
03-24-2009, 01:13 PM   #45
Sean Nelson's Avatar
QuoteOriginally posted by ogl Quote
Well, since the button shows a hexagon inside a frame, and since the green hexagon is the AF locked signal, I suspect this button selects the AF points (center only, any point, selected point).
mamiya, pentax news, pentax rumors
A copy of the atmosphere take place through a digital medium format 40 megapixel "645 gazonk Pentax News and Rumors 7 06-14-2010 01:45 AM
Is full frame the medium format of the digital era ? ghelary Photographic Technique 2 05-28-2009 08:50 AM
Pentax to launch medium format digital camera, but only sell it in Japan? Urkeldaedalus Pentax News and Rumors 100 03-08-2009 07:01 PM
Digital medium format or film? Which way to go? diveguru Pentax Film SLR Discussion 9 12-06-2008 01:45 PM
No Medium Format Digital aritzo Pentax News and Rumors 13 04-25-2008 10:38 AM
All times are GMT -7. The time now is 03:20 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
