04-14-2009, 04:02 PM   #91
Sailor's Avatar
Actually, I think I've discovered why results of AF "tests" vary so much between different posters. I think the new firmware does, indeed, boost AF speed - but only if you follow the Rule of Thirds. If your composition is out of whack, it will fail the . . . . taste . . . . test written into the new firmware, thus forcing the camera to refuse to focus or do so only slowly and with a surly attitude.
Seriously, I can't tell any difference between my camera before and after the upgrade vis a vis AF, which is fine with me.
Jer
04-14-2009, 04:44 PM   #92
and i thought it was just me. have you also noticed how it gently uses the dust removal feature for a fraction of a second to tell you you are putting the damn horizon in the middle of the damn frame? next will be a "child mode" button (with a keylock), to aid with parrental supervision, you see (no nude pictures of pretty girls if you're underage, young man). a new age has come..
04-14-2009, 05:12 PM   #93
Arpe's Avatar
QuoteOriginally posted by Arpe Quote
Interesting I've never had a problem in TAv mode, and I use it a lot.
Wonder if the Hyper-programme bug is fixed whereby the "something I can't remember wasn't working properly so I stopped using it and have forgotten what it was"! Something like auto-ISo only working when altering aperture and not working when changing shutter.
Updated last night - this glaring error is still there. In hyper-programme (P) mode auto-ISO only works if you are changing the aperture, not the shutter speed, which is just stupid. One reason I upgraded to the K20D was to use this mode, but I never use it now because of that.
04-14-2009, 08:04 PM   #94
Ratmagiclady's Avatar
QuoteOriginally posted by Sailor Quote
Jer
Hrm, how do you figure? I pretty much always use the center focus point, , hold, and recompose, anyway.
I suspect the variations may have to do with the lenses involved. And differences in us, ...there's so many factors, but I've been judging simply by how it behaves when focusing on a single point.
04-14-2009, 08:18 PM   #95
OregonJim's Avatar
QuoteOriginally posted by nanok Quote
or do you mean this firmware update on the sony 900. turns the 900 into a camera (and sony into a decent company) :-P
It would never get past Sony's DRM...
04-15-2009, 06:49 AM   #96
Sailor's Avatar
QuoteOriginally posted by Ratmagiclady Quote
Ah . . . . but that's part of the magic of the new firmware.
Jer
04-15-2009, 02:01 PM   #97
Does the upgrade erase the individual lens AF adjustment settings?
If it does, then I need to write down all the settings first before doing the upgrade.
04-15-2009, 02:39 PM   #98
Parallax's Avatar
QuoteOriginally posted by nosnoop Quote
No. It has no effect on any of your settings. It is, however, a good idea to write them down anyway. Always be mindful of Murphy's Law!
04-15-2009, 03:07 PM   #99
QuoteOriginally posted by Parallax Quote
Thanks for your prompt reply (and advice )!
04-16-2009, 03:40 PM   #100
I just bought the camera and i want to update.
Here
Latest K20D Firmware Update : Software Downloads : PENTAX
it says that i need to have V1.01 installed before which I can't find anywhere, and by the way is there V1.02 or that was skipped. Can somebody give me some info since I am new to this and I don't want to mess something up.
04-19-2009, 05:46 AM   #101
QuoteOriginally posted by Nelepl Quote
Here
I reread that page and can't find anywhere where it says that you need to have 1.01 installed first. Under the section "Applied Product" it says "K20D (version 1.00/1.01)
Anyway, I installed the update just fine on my camera and it only had version 1.00 on it.
04-19-2009, 05:51 AM   #102
fwcetus's Avatar
Here
I don't see anywhere on that page where it says you have to have V.1.01 already in place before applying V.1.03. In fact, the page says "Applied product [-] K20D (Version 1.00/1.01)", meaning (I think) that V.1.03 is intended to be used on a K20D with V.1.00 ~or~ V.1.01.
The page does mention the V.1.01 changes and the V.1.03 changes, but does not say that you need V.1.01 before applying V.1.03, My assumption is that both sets of changes are included in the V.1.03 update.
Yes, apparently V.1.02 was "skipped".
04-19-2009, 12:39 PM   #103
Sorry it does not say on that page, but it says in the read me file when you download the update
PENTAX K20D Firmware Updating to Version 1.03
* Firmware is the software that runs inside digital cameras.
Updatable models
K20D digital SLR cameras running Firmware Ver. 1.00 and Ver.1.01
04-19-2009, 12:45 PM   #104
This means 1.00 OR 1.01
You can't have "both" versions on the same camera...
04-19-2009, 12:48 PM   #105
Updatable models
Exactly!!!! K20D cameras running Firmware Ver. 1.00 and Ver. 1.01
so again, this firmware will install on K20D cameras running firmware version 1.00 as well as K20D cameras running firmware version 1.01.
Take your pick, install on cameras with FW v 1.00 or FW v. 1.01
I happened to have FW v. 1.00 on my camera so this installed fine.
I think you are fine if you have a K20D with firmware version 1.00 or 1.01.
firmware, k20d, pentax news, pentax rumors
k20d v1.04 firmware barn154 Pentax DSLR Discussion 4 08-21-2010 02:32 AM
Firmware K20D 1.03 TCerbo Ask B&H Photo! 5 06-08-2010 06:57 AM
K20D Firmware v1.04 nanhi Pentax DSLR Discussion 5 05-13-2010 08:17 AM
K20d firmware VincenTC Troubleshooting and Beginner Help 4 12-04-2009 12:46 AM
K20D Firmware 2.0? morfic Pentax DSLR Discussion 1 11-01-2008 02:37 PM
All times are GMT -7. The time now is 08:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
