Originally posted by KungPOW Hey Ogl, Rice, or anyone not under the NDA....
What do you think about the thing we are all assuming to be a focus assist lamp on the front of the K-7.
Any chance it is actually part of the exposure system and works along with the TTL meter to determine the brightness of the scene in front of the camera?
Is it a photometer that allows the camera to AUTOMATICALLY adjust exposure compensation?
The cell determines the the area in front of the camera is bright, the TTL meter does its "18% grey thing", and then the camera automaically dials up the exposure?
Or when it determines the scene to be dark, it dials the exposure down?
Works like the room brightness eye found on modern TV sets?
I thought of this after looking at Ned's latest blog posting.
Note: I am not talking about white balance here.
Unlikely.. what stops the camera from doing the same trough the lens. If you have matrix metering you can already do "auto exp. comp". By finding brightest (white) and darkest (black) subjects in the scene and then tell how actually dark is the subject under active (main) meter segment. Set the exposure correctly without any registered exp. comp (As +/-EV in EXIF).
If you'd like to have some ambient light/white balance sensor then i imagine it being somewhere on top of the camera (prism) and/or having white/matte dome shape. Otherwise if it had lens, it would "see" the same as camera already does and give no additional information.
Its already rumoured that the cam has AF assist. The "eye" has clear plastic, that seems to be like some lens (obviously to focus light in a beam), if you use bright led you don't need such big reflector as Nikon cameras have for their incandescent assist light:
C'mon
We have to make it to 2k.
Write something.. anything.
