Originally posted by Priyantha Bleeker Well I think it won't be 1080p, but it will be 1080i
1080p and 1080i are two different 'format's.
The 1080i is the standard video signal for HD televisions, the 'i' stands for interlaced.
The 1080p is the highest quality for HD televisions, the 'p' stands for 'progressive scan'.
So 1080i is the 'lighter' variant so it should be easier to implement ?
Actually, the frame rate should also be looked together!
1080i at 50Hz is no difference from 1080p at 25Hz - they just scan the lines in different orders!
A 1080i/50Hz video signal still gives you 25 complete frames per second in 1080 scan lines. For 1080i/60Hz, it has 30 fps.
So, if we have 1080p at 24 fps or even 20 fps for a video-capable DSLR, it is just very slightly worse than a traditional 1080i video picture displayed at 50Hz, say, through a component video signal cables and a display panel.
