Originally posted by fejker I know that dave9t5. I was simply replying to ogl because he stated that the camera will be made only from steel (inner and outer shell) ... that's why I said a camera built only from steel would weigh more than the current K10D/K20D which have a metal inner shell and plastic outer shell.
Ah, I understand what you were saying.
I for some reason thought that the K20d was magnesium. Of course, it is listed as plastic shell with steel frame.
For reference, some images of current inner frames:
K10D / K-m
If the plastic shell is replaced with steel shell, then the inner steel frame is redundant and can be eliminated. The steel shell becomes the frame, which saves weight and volume.
It would explain the squarish traditional shape of the K-7. A (semi-)continuous steel shell would be a much more difficult shape to manufacture compared to either a molded plastic shell or bolted sheetmetal inner-frame.
Moving the internal steel frame to the extreme outer limits of the body has a couple of advantages:
- opens up a lot of space on the interior, so more space for "goodies" such as larger VF, or electronic guts (video circuits, sensor cooling), etc.
- increases the rigidity of the body, allowing less material (smaller/lighter).
