05-17-2009, 05:49 AM   #3046
ManuH's Avatar
QuoteOriginally posted by thibs Quote
But MTF is stored in the lens. They might just do the same for distortion & co.
They will probably be stored in both. In the body for older lenses and in the lens for newer one. That would avoid the need to upgrade the camera firmware each time a new lens is issued.
05-17-2009, 05:55 AM   #3047
thibs's Avatar
QuoteOriginally posted by ManuH Quote
Indeed that would suppress the necessary frimware update. But I highly doubt Pentax will add more lenses than required in the firmware which means they will support:
* DA/DA* for sure
* FA most probably
* F maybe
* A and prior lenses highy unlikely IMO.
They might as well introduce a system on board allowing the user himself to set profile for his older lenses. That would be neat.
05-17-2009, 06:10 AM   #3048
falconeye's Avatar
* DA/DA* for sure
* FA most probably
* F maybe
Before the confusion gets out of control here ...
The K-7 firmware can correct for distortion and CA for DA and DFA lenses, only. From the K-7 press release.
05-17-2009, 06:19 AM   #3049
Here's a bit of info I recieved from a birdie:
Magnesium Body
Sensor shift left, right, up, down and 15 degree turn
HDR built into the camera
flash sync at 1/180
5FPS
and yes as being discussed above:
Distortion Correction
Chromatic Aberration Reduction
05-17-2009, 06:24 AM   #3050
flash sync at 1/180?
What?!!!
05-17-2009, 06:28 AM   #3051
Nope. 1/250 for sure then what about 15 shift?
05-17-2009, 06:42 AM   #3052
RaduA
Guest
QuoteOriginally posted by Dams2One Quote
Wanna bet? I always need that DA*300 that eluded me so far !
Radu
05-17-2009, 06:49 AM   #3053
QuoteOriginally posted by dopeytree Quote
Magnesium Body
flash sync at 1/180
5FPS
Now these would be absolutely killer features for landscape work. Mainly HDR, distortion correction and CA reduction. What would be the function for sensor shifting? Tilt-shift emulation via body?
05-17-2009, 06:49 AM   #3054
RuiC's Avatar
QuoteOriginally posted by blende8 Quote
I doubt that these data are stored in the lens.
I think they are stored in the camera.
As the patent says it is stored in a chip in the lens. That's why the Marketing director for Pentax said in an interview that DAs needed some changes on the mount. It is more logical that each lens carries its own info rather than a body which would have to be updated whenever a new lens was announced.
05-17-2009, 06:54 AM   #3055
Moderator Emeritus
QuoteOriginally posted by RaduA Quote
Radu
I'm not connecting the dots? what does flash sync 1/250th or whatever have to do with 300mm?
05-17-2009, 06:58 AM   #3056
RuiC's Avatar
Magnesium Body
flash sync at 1/180
5FPS
QuoteOriginally posted by Maffer Quote
I suspect it matches. We expected x250 but it looks like x180 is definitive, unless you can change via firmware
As for the 15 tilt, perspective correction in body like shift lenses. That's why the OK button has those arrows.
5fps maybe with the battery grip only, I guess.
05-17-2009, 06:58 AM   #3057
RaduA
Guest
QuoteOriginally posted by Peter Zack Quote
Hi, Peter!
Dams2One seems very sure about his info. I suggested a friendly bet that will help me buy the DA*300
Radu
05-17-2009, 07:05 AM   #3058
RuiC's Avatar
Hi, Peter!
Radu
You win. I'm also buying the DA*300. I have already the front dust cover. I need the rest.
05-17-2009, 07:09 AM   #3059
ogl
ogl's Avatar
Magnesium Body
Not precise information
Not precise information15 - funny. where did you get it? why 15, not 20 or 30, or 10.
flash sync at 1/180
maybe, yes...
5FPS
it's not important features. it's secondary features.
05-17-2009, 07:17 AM   #3060
er1kksen's Avatar
QuoteOriginally posted by RuiC Quote
If, in fact, the K-7 has sensor-based tilt/shift, it will NOT be through the OK button. Too many users who have no idea what tilt/shift is would get confused by it and end up not liking the results. Besides, the icon with the arrows on the OK button is almost certainly for AF point selection (and the button to its right is almost certainly picture mode selection, and yes, some people do shoot jpeg. Not to mention you can't shoot RAW in video, so that's likely to be especially useful there).
We're missing our old bracketing button, so I'm assuming that's also been relegated to the menus, so I suspect that's where the T/S (if it exists) is located as well.
On another note, if the lens corrections are confirmed to work only with DA and DFA lenses, all those FA limited users are going to be quite a bit dissapointed... perhaps a solution would be profiles for older lenses that you can load onto the camera and then select manually when you've got that lens on the camera (kind of like dialing in the focal length for SR with pre-F lenses)?
pentax news, pentax rumors
POST A PIC TO OWN THE PIC ABOVE! (Game) ll_coffee_lP Mini-Challenges, Games, and Photo Stories 788 08-01-2015 01:01 AM
Who out there would prefer a K30D? Ben Hunt Pentax DSLR Discussion 45 11-05-2010 06:48 AM
What would we want from the K30D? offertonhatter Pentax News and Rumors 102 04-22-2009 02:30 AM
So... is the K30D actually going to have autofocus? SupremeMoFo Pentax News and Rumors 88 01-03-2009 05:53 PM
Iso 1600 pic and a Butterfly Pic... Eastern Shore Charlie Post Your Photos! 5 07-06-2008 10:27 AM
All times are GMT -7. The time now is 04:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
