05-17-2009, 10:30 AM   #3106
UGH why no 1080p
05-17-2009, 10:33 AM   #3107
QuoteOriginally posted by PNTXFTW12 Quote
UGH why no 1080p
why do you need 1080p?
05-17-2009, 10:35 AM   #3108
KungPOW's Avatar
QuoteOriginally posted by illdefined Quote
Pentax's SR already supports 'twist' and X and Y at the same time. It was marketed as such with the K20
Not Z axis though, as that would affect focus.
Yes, thats 3 degrees of movement (yaw on Z axis, plus travel on X & Y). I'm wondering if Pentax has figured out how to cover the other 3, giving us SR for all 6 degrees of movement.
And, yes movement along the Z axis would affect focus. That is the point. If the camera shake is along the Z axis, then to keep the object in focus, you need to move the sensor along the Z axis.
This is just me thinking outloud, and speculating. I think that a full 6 degree movement SR system would be far more usefull then the ability to tilt/shift the sensor for creative control. Maybe the K-7 can do both?
05-17-2009, 10:39 AM   #3109
mattdm's Avatar
QuoteOriginally posted by KungPOW Quote
You mean because the camera moves that much away from the subject? I think that'd only come into play if your "shake" is on the order of an inch or more.
05-17-2009, 10:42 AM   #3110
blende8's Avatar
1/180 s flash sync is wrong.
1080i is also wrong.
05-17-2009, 10:46 AM   #3111
ryan s's Avatar
QuoteOriginally posted by dave sz Quote
Cause all the cool kids have it. Remember...there's no point in buying anything unless it's top of the line. 720p just doesn't work (for bragging rights, that is)
Z-axis correction would be great for macro. Yes...some of us hand-hold for macro :ugh:
QuoteOriginally posted by blende8 Quote
Yep
05-17-2009, 10:48 AM   #3112
QuoteOriginally posted by janneman Quote
If if so, it wouldn't be toop hard to make an "allignment correction" thingy... I mean, eliminate the tilt we see once in a while to very often...
automatic horizon leveling would be a cool feature (as long as it could also be turned off), but i doubt the SR system has such minute control. i think the mechanism is based on momentum, not gravity.
05-17-2009, 10:49 AM   #3113
Z-axis correction would be an engineering nightmare. I hope Hoya's management won't ever decide for this feature, because all the engineers involved would immediately commit suicide.
05-17-2009, 10:50 AM   #3114
DAZ
DAZ's Avatar
I am not saying the moving the sensor along the Z-axis is a good or bad thing only that it would not be 1:1 to the other side of the lens. So an extremely same movement of the sensor could translate to a relatively large change in focus.
DAZ
05-17-2009, 10:54 AM   #3115
QuoteOriginally posted by Gimbal Quote
Are you sure about the twist thing? I believe that is a myth actually, as I have never seen any official data about that. (Though I haven't read that much about the k20 as I'm a k10 owner, but they said the same thing about the k10 in the beginning.)
yes, i've seen the official material in a couple of places, including the Magic Lantern books (does that count as official?). Pentax has been marketing it that way at least as long ago as your K10..
Pentax K10D Review: 1. Introduction: Digital Photography Review
05-17-2009, 10:59 AM   #3116
the lens mount is a fixed distance from the sensor for a very essential reason. what you're describing is a job for continuos focus.
05-17-2009, 11:02 AM   #3117
KungPOW's Avatar
QuoteOriginally posted by mattdm Quote
You mean because the camera moves that much away from the subject? I think that'd only come into play of your shake is on the order of an inch or more.
I think Z axis movement of the camera would produce the least affect on focus, when compaired to either X or Y movement. You are right, unless your DOF is very shallow, the camera would need to move a distance greater then the sensor could compensate before Z axis SR would be useful.
But, camera rotation on the X and the Y axis would cause image blur as easily as movement along X & Y.
And you cannot compensate for X/Y yaw without allowing the sensor to move on the Z axis. A simple linear movement would not be enough, the sensor would need to tilt side to side and up and down.
It is the addition of SR to compensate for X/Y axis camera rotation that I think would be the big step forward. Z axis movement compensation would be a minor addition.
05-17-2009, 11:08 AM   #3118
jeffkrol's Avatar
A little bubble level is cheaper.... as far as I know most (not all) of the "alignment thingy" is not the sensor nor body, just the mask...
05-17-2009, 11:12 AM   #3119
DAZ
DAZ's Avatar
I thought I had been following this thread closely (but it is so long I may have missed it) but I donít remember anything about this. This is from the flickr New Pentax K model pool. pentax_k_7_01 on Flickr - Photo Sharing!. What are the things above the flash that look like LEDs? Are they LEDs for low light focus assist?
DAZ
05-17-2009, 11:14 AM   #3120
QuoteOriginally posted by jeffkrol Quote
You are right ofcourse. Stil, it would be usefull as it os probably the most made User Error. That is why tilt control is in just about every PP prgram,
yeah it is momentum based as far as I know but it could be "taught"to respond to camera movement as a result of pressing the button based on movement.
Then IF we get GPS in a camera it may be able to respond to that or maybe somewhere deep in the body is a small gyroscope
pentax news, pentax rumors
POST A PIC TO OWN THE PIC ABOVE! (Game) ll_coffee_lP Mini-Challenges, Games, and Photo Stories 788 08-01-2015 01:01 AM
Who out there would prefer a K30D? Ben Hunt Pentax DSLR Discussion 45 11-05-2010 06:48 AM
What would we want from the K30D? offertonhatter Pentax News and Rumors 102 04-22-2009 02:30 AM
So... is the K30D actually going to have autofocus? SupremeMoFo Pentax News and Rumors 88 01-03-2009 05:53 PM
Iso 1600 pic and a Butterfly Pic... Eastern Shore Charlie Post Your Photos! 5 07-06-2008 10:27 AM
All times are GMT -7. The time now is 04:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
