Originally posted by Caat
What are the advantages of not having an internal flash?
- Teeny weeny size and weight saving?
Won't make much of a difference indeed, but could make the design of the top of the body a lot easier, since making an internal flash that sticks out high enough to avoid red eyes as much as possible means making the top relatively long.
Versus the advantages
- Having a flash with you all the time (even if it isn't as powerful as an external unit its still more powerful than no flash at all!)
It is practical to have a fill-in flash without extra carrying, but not as conventient as you may suggest. I only use it as a fill-in in combination with my primes, as I'm only sure with those lenses that the flash won't be blocked by the hood of the lens. My other frequently used lenses (the DA* zooms) are not compatible.
- For controlling flashes wirelessly
Indeed, but the optical triggering system is far from perfect. Often I find the built-in flash not powerful enough for the remote flashes to pick up its signal. I have abandoned using it altogether and rely on a Cactus trigger for all remote flash work now. That requires a full manual setup, but this is needed anyway in most cases.
Why would Pentax not include a flash? Cost saving? Surely this offset by the fact that many people won't by a camera without an onboard flash.
I guess since Pentax were the first to make a SLR with a built-in flash (the SFX) they have the right to remove it again?
But I guess they won't. I'm counting on an internal flash.
Wim
