04-28-2009, 03:06 PM   #1306
er1kksen's Avatar
Wouldn't we have seen a Samsung-owned patent application for a new sensor, though? I don't remember hearing about that, but I'm not too sure what the rules are for patent disclosure for multinationals any more.
Did we see the patent for the current 14.6mp sensor prior to when they announced the K20D? I wasn't a member back then, so this is not a hypothetical question. Was it known prior to announcement?
04-28-2009, 03:11 PM   #1307
benjikan's Avatar
QuoteOriginally posted by mattdm Quote
I don't think it'll be radically new. I think it'll be mark II of the same sensor.
Ditto...
04-28-2009, 03:18 PM   #1308
Caat's Avatar
I agree. There were no major failings with the K20D sensor and all in all it was an excellent first attempt by Samsung.
Samsung will have been working on this sensor for its NX system, and I doubt that it has been resting on its laurels, but I would hazard a guess that the raw silcon will be the same 14.6mp core as the current sensor.
I do expect some improvements but mainly in terms of the supporting parts of the chip. My knowledge of sensor design is limited so apologies if I say something stupid but I am hoping for:
- tweaking or improvment of the microlenses (gapless?)
- increasing the readout speed of the chip
- a better ADC with better signal to noise ratio (this chip has an integrated ADC doesn't it unlike the K10D which was seperate?)
04-28-2009, 03:30 PM   #1309
New patent applications are generally published 18 months after filing, with some exceptions. And to have a patent granted, the subject matter needs to be novel and inventive (i.e., not an obvious improvement) over the prior art. If you know in advance you're not likely to meet that standard, it's likely you won't even file.
So if it's a new sensor with only incremental changes over the existing one, there might not be a patent application. And even if there is a patent application, it might still be in the pre-publication phase when it is kept confidential.
04-28-2009, 04:19 PM   #1310
mattdm's Avatar
In fact, I hope this is the case. A new sensor is likely to come with a whole new set of surprises and possible flaws (the heat issue with really long exposures with the K20D's sensor, or the banding with the K10D's. Not that those are horrible, but they're areas which could be improved). A second iteration allows those flaws the be worked out one of the reasons the K100D is so nice is that its 6Mpix sensor was basically refined to perfection.
04-28-2009, 05:33 PM   #1311
Pictures found in Russian Pentax forum
04-28-2009, 05:46 PM   #1312
er1kksen's Avatar
That "mic" port excites me. Does Samsung currently make any video equipment (as in mics that would plug into a port like that)?
04-28-2009, 05:48 PM   #1313
Metalic knobs look really nice.
04-28-2009, 05:58 PM   #1314
I'm hoping for a smaller body as well; the limiteds deserve a body that better matches their smaller dimensions. Something like the K2000/K-M in size, but with a few more K20D-class features and, maybe even more. HD video, faster shutter speeds and improved images at the higher ISO end.
04-28-2009, 06:02 PM   #1315
falconeye's Avatar
Well spotted.
They are all by Om81 (his birth date) and there are more of him:
04-28-2009, 06:15 PM   #1316
Whoah!!! That one really tickled my b@!!s!!! I can't stand the strip tease anymore!
04-28-2009, 06:30 PM   #1317
falconeye's Avatar
A trend on technical specs
My German forum starts to converge on technical specs. I don't know why, though ...
They are the same as mentioned earlier above.
EDIT...
I somehow missed that the same specs already appeared higher up in the thread. Sorry about this. Deleted my pointless info now...
04-28-2009, 06:35 PM   #1318
jeffkrol's Avatar
These seem to be the constants:
- 15 MP APS-C
- ISO 50-6400
- viewfinder with magnification 0.95x or higher (1.1x), coverage 95% or higher (100%)
- 1080p video possibly only at 15fps?
- Contrast AF (available in video too, but at 5fps only?)
- Contrast AF uses 77 areas of contrast, called AF points in LV ...
- 77 light metering zones, probably only in LV too
- 16 light metering zones still w/o LV (probably)
- Phase AF still using 11 AF points (SAFOX VIII?)
- 1/8000 & 1/250 sync possible, but old spec possible as well.
- 10 fps 6 MP mode possible
- JPG framing function
I see a trend here but cannot claim these data are accurate.
I'm sorry, but that is so vague as to be totally useless.......
04-28-2009, 06:37 PM   #1319
falconeye's Avatar
QuoteOriginally posted by jeffkrol Quote
Jeff, this may turn out to be wrong in the end (I think not).
But it is not vague
04-28-2009, 06:42 PM   #1320
jeffkrol's Avatar
But it is not vague
Well all it says to me is updated live view w/ rudimentary video capabilities... maybe I'm just blind...
Oh and CMOS 'cropping" capabilities.
Improved sensor and ADC would be real news....
or adjustable meter baseline or white balance coefficient import along w/ curves.... opps that's nikon.....
pentax news, pentax rumors
POST A PIC TO OWN THE PIC ABOVE! (Game) ll_coffee_lP Mini-Challenges, Games, and Photo Stories 788 08-01-2015 01:01 AM
Who out there would prefer a K30D? Ben Hunt Pentax DSLR Discussion 45 11-05-2010 06:48 AM
What would we want from the K30D? offertonhatter Pentax News and Rumors 102 04-22-2009 02:30 AM
So... is the K30D actually going to have autofocus? SupremeMoFo Pentax News and Rumors 88 01-03-2009 05:53 PM
Iso 1600 pic and a Butterfly Pic... Eastern Shore Charlie Post Your Photos! 5 07-06-2008 10:27 AM
All times are GMT -7. The time now is 04:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
