04-29-2009, 06:05 AM   #1396
falconeye's Avatar
QuoteOriginally posted by dopeytree Quote
I don't think 38.6 Mbits/sec is going to have chunky artefacts eh?
No, it doesn't and it as good as it gets in any consumer product right now.
However, this is only 206 kB per frame. Assuming the time compression makes for about 50% over still images, this is about 400kB per frame.
My average K20D image, when resized to 1080p, requires JPG compression quality 7/12 (in PS) to become about as big.
Attached is a comparison of qualities:
- Original 1:1 (100%) crop from K20D
- Uncompressed, but resized to 1920 width
- Compressed at JPG quality 7/12 (medium), as to be expected at 38.6 Mbits/sec bitrate.
The latter two have been resized to the original resolution of the K20D. They look better before the upscale, of course. But also making the comparison harder.
So, the smaller size and the compression both do their bad on IQ. The resizing about as much as the compression.
Note that consumer HD camcorders record at much lower bitrates!
P.S.
What is the Bluray spec?
A 2h movie stored on 50GB Bluray translates to 56 Mbits/sec ... (without the audio and the specials)
04-29-2009, 06:07 AM   #1397
QuoteOriginally posted by ogl Quote
50% of Pentaxian will be gone into ecstasies, 30% will grumble...
20% will stay with old cameras...I guess...
Maybe I'm wrong...
I believe 50% of the Pentaxians will go "Pentax is doomed, they have got it wrong again, why doesn't it have x instead of y? Why can't Pentax get things right?". Of those, 30% will jump ship beacuse the camera is "too small", but on the other hand we will get many new Pentaxians coming over from Canon because "Canon is too big".
15% of the users will complain about the lack of a pink colour scheme for the outer design, and 23% will say "K20D is a much better looking body" and another 23% will complain about the position of the green button, but 18% will compalin about the existence of a green button and 43% will be confused about the lack of an Fn-button. "Why has Pentax changed the ergonomics? Now I must learn a new way of pressing buttons!". Of course 32% will complain about the direct access to ISO, of those 32%, about 89% has misinterpreted how ISO is set, and 43% thought ISO was always set to ISO 12800, but 20% asks the question - "where is the button for the ASA setting?"
12% of the first buyes will have the camera serviced because "couldn't get the camera to accept my Fuji Velvia slide film in the SD card slot".
14% will have tried to open the K7 in a darkroom and putting the SD card onto the film development tray, and then phoning Pentax service about how many minutes it should stay in the developer because still after 15 minutes there is no glimps of an image being showned on the card..
04-29-2009, 06:12 AM   #1398
Torphoto's Avatar
QuoteOriginally posted by RMabo Quote
Hahahhahahahaha so true
You forgot all those wanting their old m lenses to auto meter
04-29-2009, 06:14 AM   #1399
QuoteOriginally posted by Torphoto Quote
I knew more info would leak out but some of the specs are scarey, partially not believeable like the 5fps and 77 metering zones. I would believe 3.5fps with a 5 fps 6mp mode yes..
5 fps is real, but not with highest resolution, still more resolution than the limited 20 fps burst mode in the K20D. Should work for most things.
77 metering zones, yes.
Why not? 16 zone evaulative metering is old now. The others has gone past 16 zones for decades ago...
04-29-2009, 06:16 AM   #1400
I would love WR in all my lenses especially in the limiteds!
Will not happen, the seals takes up too much space. Limiteds are meant to be the smallest lenses on the market. They would be too big with all the rubber seals inside and outside.
04-29-2009, 06:17 AM   #1401
I
- No contrast AF (Even Canon 5DmkII cannot focus while in video mode ...)
It has contrast AF.
Why be so surprised? Panasonic G1 has it...
Olympuas has contrast AF too.
04-29-2009, 06:21 AM   #1402
15 MP NEW APS-C CMOS SENSOR
Not entirely new, tweaked version of the existing 14.6Mp with less noise.
ISO 50-6400
Done in software, Pentax has experimented with this before (K10D prototype).
77 AF points in LV
Yes.
11-point TTL double-cross sensor
SAFOX-system being updated, but I don't know the number of AF sensors.
|quote]
77 zones light metering
[/quote]
Yes.
1/8000 shutter with 1/250 sync
Most likely yes.
04-29-2009, 06:21 AM   #1403
ManuH's Avatar
Come on, the A700 and E-3 did it in 2007, even the middle-class D90 does 4.5fps. OK the 5D mk II does only 3.9fps but it's 21MP.
04-29-2009, 06:28 AM   #1404
gazonk's Avatar
I'm sure you mean the DIN setting?
04-29-2009, 06:35 AM   #1405
I took this file from a dpreview sample of the K20D: http://72.32.185.217/~estone/extra/imgp9698.jpg.jpeg
rotated (it was portrait not landscape) and resized to 1920x12** I then opened a 1920x1080 file in photoshop and placed the photo in it, this cropped part of it. I then saved it as a jpg at 12 quality: http://72.32.185.217/~estone/extra/K-7%20video%20frame%20simulation.jpg
and opened in quicktime I then exported the file as a h.264 .mov file with quality at 3080 Kbit/sec
giving this file:
http://72.32.185.217/~estone/extra/K-7%20video%20frame%20simulation.mov
and here's a 100% crop from the above: http://72.32.185.217/~estone/extra/K-7%20video%20frame%20simulation%20100%.jpg
Not quite sure why there's a bit of colour change though.. but compare the quality of later .jpeg to the .mov file and you should have a rough idea of the quality to expect from full HD video
but this gives no indication of rolling shutter etc as it's just a simulated still.
04-29-2009, 06:52 AM   #1406
falconeye's Avatar
giving this file:
My consideration 10 posts ago may be more accurate.
The entire thing about H.264 is the time compression (compression along the time axis, not just along the spacial axes). Compressing a single frame tells you NOTHING!
E.g., a scene from tripod with a few moving cars only will yield much better quality than a handheld or a turn with varying perpective.
Which is why camcorder demo movie on vendor websites tend to show flowers smoothly bending in the wind
04-29-2009, 06:57 AM   #1407
QuoteOriginally posted by Edvinas Quote
I have suspicion that many forum members already have K-7 photos Interesting, who is going to post them first?
Rice of course. Including another mind-blowing set of exclusive specs.
04-29-2009, 06:57 AM   #1408
Hardly a valid point, wristwatches are made watertight with rubber seals.
04-29-2009, 07:04 AM   #1409
jeffkrol's Avatar
QuoteOriginally posted by Gimbal Quote
Well I don't quite agree w/ Roland but this analogy is no good. Watch has few moving parts external. I was just thinking about the seals in aperture rings and focus rings alone... I'm sure it's just a cost factor or lack of wanting to re-design... I'd wait and see what the supposed "new line" does/is.....
04-29-2009, 07:09 AM   #1410
Pål Jensen's Avatar
You said exactly the same thing about Pentax being unable to make a more advanced camera than the K20D smaller due to weather sealing and SR. It is not true. The seals hardly take any space and electronics can be made very small indeed; particularly now when theres no restrictions from the film spool and path....
Wheather sealing is no problem for the Limited lenses and I'll expect the next generation of these lenses to have that feature.....
pentax news, pentax rumors
POST A PIC TO OWN THE PIC ABOVE! (Game) ll_coffee_lP Mini-Challenges, Games, and Photo Stories 788 08-01-2015 01:01 AM
Who out there would prefer a K30D? Ben Hunt Pentax DSLR Discussion 45 11-05-2010 06:48 AM
What would we want from the K30D? offertonhatter Pentax News and Rumors 102 04-22-2009 02:30 AM
So... is the K30D actually going to have autofocus? SupremeMoFo Pentax News and Rumors 88 01-03-2009 05:53 PM
Iso 1600 pic and a Butterfly Pic... Eastern Shore Charlie Post Your Photos! 5 07-06-2008 10:27 AM
All times are GMT -7. The time now is 08:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
