04-28-2009, 09:21 PM   #166
Kguru's Avatar
Okay Ned B has practically ruled out 35mm FF, I will happily settle for 1.1x crop. Howzat?
Seriously though, I reckon a 1.2x crop with 1.5x voluntary setting per lens and K20d+30% price would be a very very tempting compromise.
04-28-2009, 09:45 PM   #167
ogl
ogl's Avatar
QuoteOriginally posted by *isteve Quote
The main issue is the performance of Pentax FA lenses on FF.
On APSC, several prime FA* and LTD lenses have worse edge performance wide open than the 16-50. How is that performance likely to improve on FF?
Very easy.
Put FAJ18-35/4-5.6 at 5D and you will see...
04-28-2009, 09:56 PM   #168
QuoteOriginally posted by Asahiflex Quote
Well, I have a 5D and a K20D, and I can assure you that almost all of my old FF lenses (and I own quite a few lenses, like SMC Takumars (24 up to 200mm), Carl Zeiss Jenas) are doing quite well on FF. I have not noticed weak corners on any of my pictures. But maybe that's because of my shooting style, as I almost never take photos at infinity, and never choose architecture as a subject, so maybe that's why I didn't notice it.
Would I say someting stupid if I say that I'm under the impression that the FF lenses I own work better on the 5D than on the K20D (yes, I know the 5D has less resolution than the K20D).
Don't be too harsh on yourself, you just probably have a failling eyesight, it's normal after a certain age... I must be experiencing similar problems...
No amount of actual experience of using Pentax 24x36 lenses on FF will do... the Truth has been spoken: Pentax lenses aren't up to the task. Better get along with it, even if you have countless shots that you find quite OK... it's just a question of you having low standards.
Anyway, did you spend enough time measurbating your gear?... didn't think so!
If you're not able to produce a complete set of brick wall tests shots (preferably with direct comparisons with corresponding DA lenses on K-7), what value does your experience carry...?
Anyway, your 5D is now obsolete and that's probably the reason it's performing acceptably with old glass: better drop it all in the trashbin as I just did.
04-28-2009, 11:53 PM   #169
thibs's Avatar
QuoteOriginally posted by Kguru Quote
Okay Ned B has practically ruled out 35mm FF, I will happily settle for 1.1x crop. Howzat? .
He ruled it out short term.
That wouldn't change the problem, if most modern Pentax lenses are not 1.2x crop compatible (and they are not) the problem is not much solved.
04-29-2009, 12:57 AM   #170
Ash
Community Manager
Ash's Avatar
Lots of hoolabaloo about this K-7 everywhere now...
I want to see it in the flesh!
Isn't it 21st of may yet, dammit?!?
04-29-2009, 10:40 AM   #171
Wheatfield's Avatar
The practical limit for sensor size, unless in body SR is dropped, is probably somewhere in the 20x32mm range to allow the best possible corner coverage with legacy glass.
What this works out to as a multiplier, I don't know.
The advantage that soynikanon has with full frame is that they aren't using camera body SR.
For myself, I think Pentax has taken the right path with their shake reduction method (I like having 50 lenses with SR).
It doesn't alter the fact that most of the DA lenses don't cover the 35mm format, so a new lens line would be required anyway.
They can't really sell a camera body without glass to go along with it.
04-29-2009, 10:45 AM   #172
thibs's Avatar
Sony has 'SR' with FullFRame tought IMO it is gimmick marketing claim.
04-29-2009, 10:45 AM   #173
deejjjaaaa's Avatar
Sony has in body SR for FF (A900)
Super Steady Shot with Full Frame Sensors
04-29-2009, 10:48 AM   #174
deejjjaaaa's Avatar
QuoteOriginally posted by thibs Quote
do not forget that Sony has different mechanism for SR vs Pentax... if Pentax can't stabilize heavier and bigger FF sensor the way APS-C sensor is stabilized, that's their problem - they need to buy a patent(s) from Sony.
04-29-2009, 10:51 AM   #175
thibs's Avatar
QuoteOriginally posted by deejjjaaaa Quote
I have no read official info on that so until proven it is rumour.
Sony has 'SR' but if I remember well, it goes as far as 0.5-1 EV with FF lens. A gimmick.
04-29-2009, 10:57 AM   #176
Wheatfield's Avatar
I hadn't realized Sony had put SR into a full frame body.
Any reports of how the corner performance is with older Minolta glass? This would be the benchmark I'd be interested in.
If they are releasing new glass with an increased image circle to make it work that's something, they don't have Pentax's backwards compatability albatross that might prevent them from releasing a technology that doesn't cut it.
04-29-2009, 10:58 AM   #177
thibs's Avatar
Look at the 35/1.4 Sony re-released recently... have a good laugh
04-29-2009, 11:01 AM   #178
Wheatfield's Avatar
Links? I'm doing my income tax today, I could use a laugh....
04-29-2009, 11:03 AM   #179
Pål Jensen's Avatar
Pentax have FF stabilization patents from years back. I wouldn't be surprised if Sony is paying Pentax for its use....
04-29-2009, 11:03 AM   #180
sony 35mm 1.4 - Google Product Search
~1,369.99USD...
pentax, pentax news, pentax rumors
Ricehigh: No More Hope With Pentax Asahiflex General Talk 143 07-11-2009 12:14 PM
is RiceHigh the new benjikan of rumors? vitalsax Pentax News and Rumors 19 04-30-2009 01:56 PM
A question for RiceHigh and other 5D/Pentax users lol101 Pentax DSLR Discussion 22 04-09-2008 10:12 AM
Well done, RiceHigh... klopus General Talk 10 08-05-2007 05:40 AM
All times are GMT -7. The time now is 01:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
