05-06-2009, 03:22 AM   #226
QuoteOriginally posted by ogl Quote
It's camera hard to say about class. But, it's not D90 at all.
Higher. Pentax always makes special cameras. Not ordinary.
Pentax makes cameras hard to classify, they already did this with the K10D, K20D and now the new camera. "Upper popular class" or "Upper advanced enthusiast" or "Semi pro" / "prosumer" or "Amateur video prosumer still"...
Is it a still video camera or DSLR for moving pictures?
New feature - the pictures are moving so fast that the photographer may have problems catching the pictures before they have run away! Oh, the pictures comes with GPS so they can run by themselves to the lab and be developed. (if the Police is not taking them off the streets "hey, we have lots of moving pictures on the streets today, it stirs up the traffic!"...)
With moving pictures, there is no need to store them on memory card.
05-06-2009, 05:37 AM   #227
OK, I'll bite.
My guess is that the "flaw" in the body that ogl is hinting at is indeed the absence of an articulating LCD, as others have said. We all know that engineering involves compromises, and I expect that Pentax would favour greater ruggedness and smaller size over an articulated LCD.
I know that many of you won't see this as a flaw, but I for one would like to see one. It's very handy in crowds to be able to simply lift the camera overhead and compose the shot through the viewfinder.
EDIT: Um, I meant that you compose the shot through the *LCD* when it is held overhead. But you knew that, right?
05-06-2009, 05:42 AM   #228
QuoteOriginally posted by robbiec Quote
I think we can take it as a given that it will use a 3' screen with at least 920,000 pxels....
We certainly *are* taking it as a given, and the fact that the "Play" and "Trash" buttons were moved around on the back points in that direction. But we don't *know* (at least, those of us who have not had the privilege of looking at actual pictures of the K-7).
Personally, I don't think it would be a major problem if the screen was still the same. It's adequate.
Oh, and if the "one problem" with the body is not the screen, then my 2nd guess is that it runs on 4xAA cells instead of Li-Ion. *That* would bother me a lot.
05-06-2009, 05:48 AM   #229
QuoteOriginally posted by RBellavance Quote
I agree that the screen as in the K20D is adequate. However, if you want to have a look, there's an image in the currently last but one page (edit: last but one post on page 125) of the megathread that shows an vague image of the back of the camera. Sufficient to estimate the size of the screen. It seems bigger.
Wim
05-06-2009, 05:55 AM   #230
QuoteOriginally posted by Ishpuini Quote
Indeed, it does.
05-06-2009, 05:57 AM   #231
NO any problems with the body!
05-06-2009, 05:59 AM   #232
gazonk's Avatar
QuoteOriginally posted by Om81 Quote
Not for anyone? Not even the stubborn old-schoolers who hate DSLRs with video mode ?
05-06-2009, 06:07 AM   #233
blende8's Avatar
No bracketing button!
05-06-2009, 06:12 AM   #234
QuoteOriginally posted by gazonk Quote
Stubborn old schoolers don't like digital....
QuoteOriginally posted by asw66 Quote
OK, I'll bite.
I do not need an articulated screen for that. In my opinion lifting the camera overhead in a crowd is not very usefull as you only gain an arms length. That is not very much.... You are still too close to the top of the crowd and as we all know, the one guy who is much taller always stands in front of you. If you want "over crowd shots"you need a small ladder.
Or, hey, wow, I just got an idea.... Another way is ofcourse to mount the camara on a monopod, that would give you a true advantage.
Nope, that is not the idea I just had. If you'd just had a camera and a monopod, you'd need a humongous articulating LCD screen to see clearly, but what if you make a monopod with a screen and some connections between monopod and camera and ofcourse a camera that allows that....
Janneman rushes to the patent office.....
QuoteOriginally posted by RMabo Quote
It is weather sealed.
so no limtied body, none of the limited lenses are sealed.....
05-06-2009, 06:21 AM   #235
jeffkrol's Avatar
QuoteOriginally posted by janneman Quote
just go patent a wireless transmitter in the camera and a small lcd attached to your eyeball via a glasses frame. Make it eye responsive so when you blink twice it fires the camera...... Screw this old school articulating/tethered/ect. screen......
05-06-2009, 06:45 AM   #236
K-m is the Limited body, especially in the white limited edition.
05-06-2009, 06:51 AM   #237
Well, I hear that there are a lot of giants in the Netherlands, so perhaps this is a real problem for you. I suggest you should fix your camera to a periscope and use a remote release.
05-06-2009, 06:59 AM   #238
ftpaddict's Avatar
It won't have an OVF. That'd be a huge problem.
05-06-2009, 07:04 AM   #239
ManuH's Avatar
it is indeed limited
05-06-2009, 07:08 AM   #240
ManuH's Avatar
I would be disapointed by the lack of a hi-res LCD. I've seen it on the D300 and D90. It would also help for the Liveview. Now the 50D and the 500D have it. Pentax has no choice I think.
4xAA. I don't think so but it wouldn't bother me, non-proprietary batteries have their advantages. I hope they will use the same battery as K10D/K20D if it's Li-On.
camera, features, k-7, lot, pentax, pentax news, pentax rumors, semi-pro, specs
More K-r Specs Adam Pentax News and Rumors 138 09-13-2010 12:54 PM
K-X specs o_bender Pentax DSLR Discussion 17 10-09-2009 09:32 AM
k-7 specs?? houstonmacgregor Pentax News and Rumors 11 05-19-2009 05:26 PM
Specs on MZ-S mr.voigtlander Film SLRs and Compact Film Cameras 2 02-08-2008 02:46 PM
GX-20 Specs ricardobeat Pentax News and Rumors 5 01-24-2008 10:01 AM
All times are GMT -7. The time now is 09:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
