05-06-2009, 02:48 AM   #91
Asahiflex's Avatar
Beware of the trap
Don't look at the K20D photo you posted. Take your K20D and look at it directly.
You'll notice that it will look exactly as the mirror box in the K-7 press kit photo (which shows the reflected ground plate) and not like in the K20D photo you posted. Even the faint details coming from the ocular are the same ...
I think the differences are due to the fact that the K-7 press kit photo was taken from a slight angle and not exactly horizontally (like the K20D photo).
Mmm....
05-06-2009, 02:49 AM   #92
QuoteOriginally posted by Asahiflex Quote
I still think I'm right though. Proof: what with the loose space below what you call the mirror in the K-7 photo? I have changed the screens in K10D's and K20D's many times.
Edit: on the other hand it would be strange that the screen does not have a tab. So maybe it cannot be proven from these photos, as the K-7 can be completely different as far as the mirror box goes.
Maybe the mirror "canvas" is bigger to be "future FF-compliant".
WARNING: Not a FF rumor!
05-06-2009, 02:59 AM   #93
QuoteOriginally posted by Rush2112 Quote
Nice specs on that viewfinder, being 100% x 1.0x is dooable on APS-C
Doable, yes. But don't get your hopes up too high
05-06-2009, 03:02 AM   #94
blende8's Avatar
You can see the clip of the screen holder.
The holder is down.
At the top is only a black hole in which the clip snaps in.
05-06-2009, 03:11 AM   #95
falconeye's Avatar
QuoteOriginally posted by zntgrg Quote
If the ground plate (canvas) would be bigegr, so the mirror and the box which the mirror sits in.
Because the box is the thing which can be measured the best (from the photo -- closest to mount opening, least parallax error), I'll say no difference in size here...
EDIT:
Not necessarily correct.
The mirror box must be large enough for the 100% APS-C sensor already. So, please ignore what I have written above
Last edited by falconeye; 05-06-2009 at 03:17 AM. Reason: detected a flaw in the reasoning
05-06-2009, 03:11 AM   #96
As for SAFOX VIII or IX - the K-m has, technically (hardware), the same AF system as the *ist DL2. But, it has new software algorithms which makes it faster, especially in low light. Still, it isn't called SAFOX IX.
If the system is technically, hardware, the same as previous versions but uses new software algorithms, Pentax can still use the old name. But if it also has new hardware (new sensors, new AF processor etc.) a new name is used.
Most important is that there is an improvement, and it will be, rather than if it is having VIII or IX. The version number itself does not say about the performance, as the K-m shows.
But yes, it is confusing for the user. Perhaps Pentax should simply call it SAFOX and leave it there.
05-06-2009, 03:13 AM   #97
falconeye's Avatar
QuoteOriginally posted by blende8 Quote
The holder is down.
blende8, didn't you think I noticed this as well and took into account Come on, by now, you should know me better
If taken from the angle the K-7 photo was taken at, the clip isn't visible directly anymore (becomes hidden due to parallax). But its reflection in the mirror becomes visible.
As I said, try it out with your K10D/K20D
So, you do see the mirror (actually not because it is too black) and the reflected ground plate (which is a better measure anyway). But because you don't know the shooting distance (the perspective error), you still cannot determine its size relative to the mount size. Not if we speak 95% vs. 100% here. (You could still determine a minimal coverage assuming an infinite shooting distance, though ... -- by comparing gound plate image to mount opening; but I doubt the figure will be larger than 95%)
05-06-2009, 03:14 AM   #98
Good question
QuoteOriginally posted by RMabo Quote
what does SAFOX mean??
05-06-2009, 03:29 AM   #99
blende8's Avatar
Man, you are right!
Here's the view: (top K10, bottom K7)
This absolutely fascinating!
05-06-2009, 03:31 AM   #100
blende8's Avatar
QuoteOriginally posted by janneman Quote
Pentax Auto Focus Systems
05-06-2009, 03:42 AM   #101
falconeye's Avatar
Man, you are right!
Stored for future use
Wieland, thanx for your acknowledgement. I very much appreciate your work and opinions here and in DFN.
05-06-2009, 04:03 AM   #102
Asahiflex's Avatar
Man, you are right!
OK, I hereby declare officially that I was completely, totally, 100% wrong
05-06-2009, 04:11 AM   #103
Kenn100D's Avatar
One part finally completed. Now we can sum it up for the other missing pieces of the puzzle.
05-06-2009, 04:12 AM   #104
Yes, Indeed
05-06-2009, 04:25 AM   #105
QuoteOriginally posted by Om81 Quote
Yes, Indeed
Perspective comes into play.
af, algorithms, days, movie, pentax news, pentax rumors, sensor, system, time, viewfinder, wb, whilst
Image of K-5 Leak noahpurdy Pentax News and Rumors 42 09-13-2010 10:27 AM
Back to the leak jeffkrol General Talk 5 06-10-2010 10:01 AM
What are these .. light leak? mypentaxticworld Pentax Film SLR Discussion 45 03-31-2010 05:26 AM
Random Dim Sum Shots w/DA 21mm legacyb4 Post Your Photos! 8 01-04-2010 06:40 PM
Cogito ergo sum! Camilsky Post Your Photos! 4 01-28-2008 05:57 PM
All times are GMT -7. The time now is 08:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
