05-19-2009, 10:29 AM   #1
houstonmacgregor's Avatar
k-7 specs??
Above: 7 Photos of the K-7, Kit and Grip! ;-D
K-7 Specifications:-
Camera Name: Pentax K-7
Body Material:
Magnesium Alloy Outer Shell on Stainless Steel Chassis
Body Reliability: 77 Places Sealed, Cold-Resistant: Can be Operated under Temperature at -10C
Sensor:
New Version of Samsung 14.6MP CMOS APS-C Imager in 23.4 x 15.6mm (Aspect Ratio 3:2), 4 Data Channels Readout
Dust Removal: New DRII System, Low-Pass/Anti-Aliasing Optical Filter Placed in Front of Sensor is Capable to be Moved in High Ultrasonic Frequency; Featuring also the Dust Alert System to the User
ISO Speeds: ISO 100-3200, 6400 Available on Expansion (to be Set via Custom Function)
Image Processing:
Newly Developed PRIME (Pentax Real IMage Engine) II Image Processor for High Performance and High Speed Still Image and Movie Data Processing; Better-Quality Images with Richer Gradation and More Accurate Color Rendition
Mount:
Pentax KAF2 (Crippled K-mount, Support Both Body Driven "Screw-Type" AF KAF and SDM KAF2/KAF3 Lenses)
Viewfinder:
Optical Type, Glass Prism, 100% Image Coverage, 0.92X Magnification
Focusing Screen:
New Natural-Bright-Matte III Focusing Screen, Improved Manual Focusing Accuracy
Shutter:
1/8000th second Top Speed, X-Sync=1/180s, 100,000 Shutter Actuations Durability
Continuous Shooting Modes: Continuous (Hi):-
JPEG: 5.2 FPS: Until 40 Frames;
RAW(PEF): Until 15 Frames;
RAW(DNG): Until 14 Frames
Continuous (Lo):-
JPEG: 3.3 FPS: No Limitation, until Card Full;
RAW(PEF/DNG): Until 17 Frames
Live View: Yes: Real-time, On-display image Confirmation, Activated by One-touch Dedicated "LV" button at the Thumb Position; Continuous Shooting Possible Under the LV Mode (Without Breaking the LV Mode and Exposure will be Adjusted Automatically and Continuously Via Automatic Diaphragm)
Live View AF Options:
Contrast Detection AF with Face Recognition Option
Other Preview Options:
Optical Preview; Digital Preview
Movie/Video Recording:
Movie/Video with Mono-Audio Recording (with Built-in Microphone), Supported Video Modes: 1280 x 720 Pixels (16:9 Standard High Definition), 640 x 416 (3:1.95), 1536 x 1024 (3:2), All Modes at 30 Frames Per Seconds
Top Monochrome Status LCD:
Yes, with Electro-Luminescence (EL) Backlight
Rear Colour LCD Monitor:
3.0", 640 x 480 Standard VGA Resolution, Approximately 920,000 Colour Dots, 170 Degrees of View both Vertically and Horizontally
e-Wheels Control:
Front and Rear Wheels
Green Button:
Yes, Directly Under the Rear Wheel
Exposure Modes:
Green Mode, Hyper Program (P), Sensitivity Priority (Sv), Shutter Priority (Tv), Aperture Priority (Av), Shutter-Aperture Priority (TAv), Hyper Manual (M), Bulb (B), X-Sync (X), User and Movie
Metering System:
New 77-Segment Multi-Pattern Metering System, which Divides the Frame Equally in 7 x 11 Segments, Vertically and Horizontally Respectively; More Advanced Algorithm for Higher Exposure Accuracy
Metering Modes:
Evaluative, Centre-Weighted Average, Spot;
Selected via Dedicated Metering Mode Level at Camera Top
AF System:
New SAFOX VIII+ AF System, Layout Same As SAFOX VIII (11-Point, 9 Crossed); Improved in Speed and Accuracy
Focusing Modes:
AF-S, AF-C, MF; Via Dedicated Focusing Mode Selector Level
Dedicated AF Button:
Yes
Dedicated AF Point Selector:
Yes: Central, Auto and User Select
Built-in Flash (RTF):
Yes, Manual Pop-Up
Built-in AF Assist Light:
Yes
Orientation Sensor:
Yes
Shake Reduction: Pentax Original SR System which is Capable of Compensation Shakes in Up/Down, Left/Right and Rotational (Clockwise/Counter-clockwise) Directions
SR Activation:
Preset by Camera in Different Modes or Manually Activated/Deactivated by the User via System Menu
Image Tone Modes:
Seven Modes: Bright, Natural, Portrait, Landscape, Vibrant, Monochrome, Muted (for Delicate, Subdued Colours); Actual Effect Previewable under LV or Digital Preview Mode
Image Parameters:
Saturation, Hue, Contrast, Sharpness, Filter Effect, Toning, Key and Contrast Highlight/Shadow; Actual Effect Previewable under LV or Digital Preview Mode
White Balance Presets:
Auto, Daylight, Shade, Cloudy, Fluorescent Light, Tungsten Light, Flash, CTE (Emphasizing the Colours of Sunset Scenes) and Incandescent-Tinted Fluorescent Light
Manual White Balance:
Yes: Manual Measurement, Presets and Fine-Tuning (for Green Vs Magenta and Blue Vs Amber)
Supported Colour Spaces:
sRGB (Default) and AdobeRGB
Other Features: HDR (High Dynamic Range) Mode (One Composite Image from 3 Exposure Bracketed Images), Dynamic Range Expansion, Auto Distortion and CA Corrections, Multiple Exposures, Copyright Credits Attachment, Dedicated RAW Button, 16 Digital Filters
Controls Around Shutter Release:
Optical/Digital Preview; Two Separate Buttons for ISO Speed Selection and +/- EV Compensation / Top LCD Panel Backlight/Illumination
Direct Control System for Basic Functions:
With the Four Ways / "OK" Buttons for WB, Flash, Drive and Image Tone Mode / AF Point Selection Activation
Standard Digital Controls:
Play/Delete (at Upper Left), Info/Menu (at Lower Right)
Dedicated One-Touch RAW Button:
Yes
PC Sync Socket: Yes
IR Remote Control:
Yes, Front and Rear Receivers
I/O Ports:
Left: DC In, PC/AV, HDMI Out, Mic In; Right: Cable Switch Connector
Battery: New Type High Capacity Rechargeable Type D-LI90, 7.4V/1900mAh (Nominal), Support up to 980 Shots Without Flash
Storage Media:
SD and SDHC Cards
Dimensions:
130.5(W) x 96.5(H) x 72.5(D) mm (5.1 x 3.8 x 2.9 inches)
Weight:
670g (22.9 oz.), Body Only (Without Battery and SD Card)
750g (26.5 oz.), Loaded and Ready (With Battery and SD Card)
Software: Pentax Photo Laboratory (with SILKYPIX RAW-data processing engine developed by Ichikawa Soft Laboratory), Pentax Photo Browser and Two Other Utilities
Kit Lens:
DA 18-55/3.5-5.6 AL WR (Water/eather Resistant)
Optional Accessory:
Vertical Battery Grip D-BG4, Weather-Sealed and Cold-Resistant, Support Either Another D-LI90 or Six AA Batteries, Provision of Extra Shutter-Release Button, Preview Lever, e-Dials, AE-Lock, Green Button and AF Button
Javier Gutierrez , May 18, 2009; 12:46 p.m.
05-19-2009, 10:45 AM   #2
Well, if these specs are factual, then I'm in.
NaCl(starting to save my quarters now)H2O
05-19-2009, 10:49 AM   #3
Do we need yet another post with "specs" copied word by word from RH blog?
05-19-2009, 10:52 AM   #4
axl
QuoteOriginally posted by NaClH2O Quote
I wish to say the same, but I don't think I'll have cash for it
though it reads good...
BR
05-19-2009, 10:55 AM   #5
emr
Guest
QuoteOriginally posted by nosnoop Quote
The 100th will be given a reward.
05-19-2009, 11:28 AM   #6
QuoteOriginally posted by axl Quote
BR
Well, by the time I have enough quarters saved up the new K-8 or K-6 or K-whatever will be out and the price will have dropped enough for me to afford it. IIRC I've paid about $700 for each the DS, the K10D and now the K20D. I just wait 2 years and it's within reach!
NaCl(my body "de-appreciates" also; unfortunately I can't wait 2 years and pick up a new model )H2O
05-19-2009, 11:43 AM   #7
No, but do we have a choice?
Btw, those "specs" are not 100% taken from an official press release/specification list; the words "Crippled K-mount" proves some editing was done.
05-19-2009, 11:54 AM   #8
somehow the first line of the message did not copy: this copied from K7, the "me too" camera... - Photo.net Pentax Forum
maybe it is a gag and I missed it
05-19-2009, 02:42 PM   #9
Torphoto's Avatar
"ME Too"? Actually this, like the K10D and K20D are not "me too" cameras. The K20D did video like 21fps mode and no one too notice, every other company jumped and did real video modes and now PEntax is the first with manual controls in video mode and it's a "mee toooo"
Regardless let them claim me to all the want, we'll just be shooting while they watch in envy
05-19-2009, 03:16 PM   #10
Indianadinos's Avatar
Well, maybe this is the right time for me to switch from my K10D to a K20D ...
05-19-2009, 03:57 PM   #11
Sounds good to me. Might be time to upgrade my K10's...
c[_]
05-19-2009, 05:26 PM   #12
PentaxRev's Avatar
It's still too early for me to tell if this is the place I upgrade. On the one hand I like some of the projected new features. The improved autofocus sounds good, the improved colors etc and the 920,000 3 inch screen. However, I like the substantial size and feel of my K10D. I'm not sure I'm ready to go to something smaller. I may just upgrade to the K20D, but I'll wait until I read the reviews to see how much better the autofocus is and to see how the new K7 does at the higher ISOs.
af, button, frames, image, mode, modes, pentax, pentax news, pentax rumors, preview, shutter, system
More K-r Specs Adam Pentax News and Rumors 138 09-13-2010 12:54 PM
K-X specs o_bender Pentax DSLR Discussion 17 10-09-2009 09:32 AM
K-7: the specs are known already ogl Pentax News and Rumors 347 05-15-2009 01:16 PM
Specs on MZ-S mr.voigtlander Pentax Film SLR Discussion 2 02-08-2008 02:46 PM
GX-20 Specs ricardobeat Pentax News and Rumors 5 01-24-2008 10:01 AM
All times are GMT -7. The time now is 05:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
