05-26-2009, 08:38 AM   #136
GoldenWreckedAngle's Avatar
QuoteOriginally posted by GoldenWreckedAngle Quote
... I wish I had a nickle for every time I've pondered whether I would be happier today with a D200/D70 combo than I would with my K10D/K100D combo. The honest answer is that I had very high hopes that the next Pentax camera would solve the quandary for me once and for all. It did.
Edit: For clarification, I came so close to switching brands last year when some of my commissions forced me to start adding more expensive lenses and accessories to my kit, effectively locking myself into the Pentax system for the next year or two. Overall, I think the K-7 affirms that I made the right decision. I'm sure I would be very happy shooting Nikon today, but certainly no happier than I am shooting Pentax.
Just edited the above post for clarification. As disappointing as the 1/180 synch speed is to me, it's only one feature. I'm not sure yet if I will buy a K-7, but I am satisfied that I made the right short term decision in sticking with Pentax.
Truth is, if I do eventually switch to Nikon, it will probably have a lot more to do with availability and local support base (both borrowable and rentable gear, as well as nearby repair centers) than any feature on the camera, including synch speed. I have a buddy that will let me borrow his D70, and another one that will let me borrow his D200/D300 and nice lens line-up any time I want. My only Pentax buddy shoots weddings and portraits with an Ist-D. The mooch factor is heavily weighted in Nikon's favor.
05-26-2009, 08:43 AM   #137
and
We've gone over this several times. The gating trick on CCD sensors will not work on CMOS sensors. At least not the way it has been done in the past.
I was responding to the post about pentax waiting for samsung to make some electronic shutter on the cmos chip, saying if pentax wanted to do that they had the chance when they were using the sony chip which did have it but they choose not to so why now.
05-27-2009, 06:14 AM   #138
QuoteOriginally posted by Photomy Quote
What is the major contraint on allowing the camera shutter speed to go higher than sync speed and still take a photo with a darkened area? Some subjects can be great for this. Nikon, and Canon both do not limit shutter speed to sync speed. Why does Pentax do this? AND, this is something that could be easily chanaged in firm ware. Just add an override option in the menu somewhere.
I e-mailed Imaging Resources and they confirmed that the hot shoe on the K-7 still goes dead above 1/180. Bummer...
05-27-2009, 10:41 AM   #139
Which shutter mechanism would you guys prefer:
1. K20D noise level with 1/250 X-sync (around 40% faster)
2. K7 noise level (around 40% quieter) with 1/180 X-sync
I'd take #2 without thinking twice.
Prog.
05-27-2009, 12:11 PM   #140
falconeye's Avatar
QuoteOriginally posted by Prognathous Quote
Why can't we have a shutter gearbox?
05-28-2009, 12:19 AM   #141
so as to avoid people like you (and me) trying it in reverse ("just because you can")?
edit: do make it a cvt, please (with manual override).
05-28-2009, 07:42 AM   #142
Prog.
I'd take #1 without thinking twice.
05-28-2009, 03:30 PM   #143
After giving this a bit of thought I've reached the following conclusion. It's the same shutter we've always had. They dampened the mirror slap, that's all. Aside from carrying over the PC port from the K20D and adding a little power to the pop-up flash I don't see any improvements over the K10D's flash support.
It had nothing to do with the size limitations of the body. It simply wasn't important enough to mess with in Pentax's estimation. I don't know if it would have affected the final cost by a nickle or $100, but either way, it would have been worth at lot more to me. Maybe next time.
05-28-2009, 04:22 PM   #144
Digitalis's Avatar
the K10D's shutter couldn't do 1/8000th, and it couldn't do 5 FPS. Secondly I think they have revised the mirror control system in order to make it quicker and quieter. have you ever heard a fire it's shutter K10 with mirror lock up mode...the shutter itself is very loud.
05-28-2009, 06:47 PM   #145
DAZ
DAZ's Avatar
I think I read some were (Ned Bunnell Blog K-7 Brochure) that the PC port now has high voltage protection on it. Not saying that makes up for the limitation for you just one little add thing.
DAZ
05-28-2009, 06:55 PM   #146
mattdm's Avatar
Don't forget the other consequence of messing with things potential new bugs.
05-28-2009, 07:35 PM   #147
1/8000 was just a matter of allowing the second curtain to start closing a little sooner, 5 FPS is a result of image processor improvements, and yes, I've heard the shutter on my K10D in mirror lock up mode several times. It's the same shutter.
05-28-2009, 07:44 PM   #148
QuoteOriginally posted by mattdm Quote
True, but that goes with any progress. Maybe Pentax just felt their engineers had enough on their plate already. I definitely commend them highly for the refinements on the rest of the machine. It was a pretty full load.
05-28-2009, 08:27 PM   #149
If it was so simple, they would have done it in K20D or earlier.
No, the 5FPS requires shutter (+mirror box) upgrade. It may not be a major redesign, but you definitely need component upgrades, similar to SAFOX VIII+ over SAFOX VIII.
Sure, faster shutter speed means making the slit smaller. However, it is not as trivial as "just a matter of..." Otherwise, you would see it as standard feature in all DSLRs.
05-29-2009, 06:44 AM   #150
According to John Carlson, Product Manager Imaging Systems, Pentax USA, the shutter was not redesigned.
I'll gladly conceed that I could be wrong but I seriously doubt John is. It's the same shutter.
blade, blades, coil, constraint, movement, pentax, pentax news, pentax rumors, power, shutter, x-sync
Is 1/180th Max Flash X-Sync A Major Limitation? Christopher M.W.T Flashes, Lighting, and Studio 20 07-10-2010 08:15 AM
Lens F/stop Limitation Question seachunk2 Troubleshooting and Beginner Help 10 02-26-2010 07:27 AM
Split screen viewing limitation qestion winglik Pentax DSLR Discussion 9 06-11-2009 04:05 AM
K20D Focus adjustment limitation bc_the_path Pentax DSLR Discussion 2 12-16-2008 03:04 PM
All times are GMT -7. The time now is 01:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
