Originally posted by blende8 How do you think this is realized?
A phase detection system uses prisms (it works not unlike a split prism focusing screen). This causes a dependency on the wavelength. That is why Pentax AF front focuses under Tungsten light.
The new sensor is responsible for detecting the light temperature and it's input is used to compensate the measurement of the phase detection system.
At least that is my understanding.
Originally posted by Ray Pulley I would be hard-pressed to believe that adding a sensor that has to be read and processed and then taking that data and using it to adjust the AF would make the whole process FASTER.
Such calculations don't take any noticeably time.
Originally posted by Ray Pulley More accurate in certain lighting, yes, as that is what it is designed to do, but Faster, no.
How do you know? You may be right, but perhaps the additional information can be used to disambiguate information from the phase detection system and thus help to speed up AF? I'm not saying this is the case or even likely to be the case, but when I don't know I try to not talk in absolutes.
Originally posted by Wheatfield If you go out and use two different cameras, and one just seems to have snappier performance...
Then one
seems to have a snappier performance. Only a scientific evaluation will tell you whether you are imagining things (we humans are great in seeing things which are not there) or whether there are actually facts.
Originally posted by Wheatfield I have more interest in this sort of anecdotal approach than a purely quantifed approach that may or may not have anything to do with actual photography.
Fair enough. To become happy one should do what makes one happy. If you are happy by basing your decision on impressions that may be influenced by a lot of factors and then are happy with the result of such a decision then that would be the right thing to do for you.
To some people it is obvious that homoeopathy helps (beyond a placebo effect).
Scientific approach, it is not. -- Yoda.
