06-03-2009, 08:22 PM   #16
Miserere's Avatar
Anyone notice that the 3 hot pixels in the ISO3200 image are not present in the 6400?
06-03-2009, 08:28 PM   #17
Torphoto's Avatar
QuoteOriginally posted by Miserere Quote
I saw 2 looking for the 3rd
06-03-2009, 10:21 PM   #18
krypticide's Avatar
Not that impressed, looks more comparable to D300 than D700 (though I think D700 is actually pretty noisy at high ISO but their NR yields usable results). Anyway, still excited about the K-7, and I imagine it will only get better from here.
06-04-2009, 01:15 AM   #19
Early day's, but the ISO3200 sample looks nicer than what I get from the K200d at ISO1600.
An improvement in quality with 1 more stop makes my upgrade a no-brainer.
Similar improvement in AF would be great.
06-04-2009, 02:55 AM   #20
Steelski's Avatar
Ok, If you have only seen the Jpegs then you are missing out
I downloaded the Jpegs, and the RAWS.
The Raws only open in Faststone and convert with terrible colours.
I converted the 6400 Iso image, just plain terribly converted. The lighting level was terrible, as well as.... I will just stop there, the image was useless because of the bad conversion.
The 3200 Iso image is much better.
It processed with all its noise intact.
The 3200 Image is much better than the Jpeg,
Pushed the image One stop and it looks like 6400 Iso is great too.
One more stop and Iso 12800 is possible. looking a bit too noisy.
Basically compared to my K20D
It does not have the purple ring of noise around the image at whatever Iso,
No banding streaks up to 6400
Finer grain.
which is all I was asking for.
I have attached a 100% crop from the pushed samples to 6400 Iso,
One with no noise reduction. and the other with 95% chroma noise suppression and 30 % luminous noise suppression in Noisware pro. No sharpening.
You can guess that at 3200 Iso the result is even better, but too dark.
Anyway. IMO great.
06-04-2009, 03:02 AM   #21
Steelski's Avatar
here is the same extract from the jpeg only
same extract from 3200 Jpeg at around 6400 level
06-04-2009, 03:43 AM   #22
wll
3200iso & 6400iso Look Fantastic - But !!!!!
Both are taken at fast shutter speeds.
What I want to see is 3200 & 6400 taken at 1/8, 1/5 and 1/30.
That is where I would use them most of the time. Yep, In a low light situation, only available light, using something like a 16-50mm f2.8, a 50-135mm f2.8 or my f2.8 my 200mm FA 2.8.
Those are the images I want to see.
But ... Even though these shots are taken with early firmware, they (IMHO) look very, very good. I think this will be one heck of a camera for low light photography and along with that I think the DR will be much, much better than the K20D.
I just ran the 6400iso wall shot through my Image-Mode-Lab-Window-Channels-Filter-Noise-Meridian reducing technique and was amazed at the lack of noise reduction that was called for as compared to my K20D images taken at higher shutter speeds .... very interesting indeed !
JMHO.
wll
06-04-2009, 04:40 AM   #23
QuoteOriginally posted by wll Quote
with respect here, but just because its is better than the K20d it certainly does NOT mean that its "good"..
its simply better than K20d - thats all.. and when you accept how bad the K20 is at high ISO, then thats not saying much.
In my view - even the noise at ISO800 is terribly bad and unusable.., the 3200 and 6400 shots should be binned straight away. there is nothing to be saved from them.
06-04-2009, 05:08 AM   #24
wll
QuoteOriginally posted by StephenG Quote
The K20D IMHO is very good at high iso, it keeps the image intact instead of smearing it like C does.
I'm looking at it compared to the days when I used Ilford HP5 and Kodak Tri-X film so maybe my perception is different than yours.
INHO 800iso is great! The images are very sharp ... Pentax lets YOU decide how much noise YOU want to take out. Looking forward to using ~4500iso for concert work if need be.
Check out the dpreview of the K20D and look at the noise section of the review ..... look at how SHARP the Pentax image is compared to C & N. Granted C & N are MUCH less noisy, but like the review says Pentax is only more noisy because Pentax does not go heavy handed and smear things up.
wll
06-04-2009, 05:15 AM   #25
gazonk's Avatar
But what if you don't accept that the K20 is bad at high iso? Which (APS-C) cameras are better, in your opinion?
06-04-2009, 06:36 AM   #26
Are you just pixel-peeping at 100% or did you actually look at the entire ISO3200 image? A little noise is not a bad thing. That ISO3200 pic reminds me a lot of film scans. You could easily make an 8x10 print from it. So long as there's no banding noise can actually be another creative tool. Hell, I run most of my pics through Alien Skin Exposure to simulate film anyway because most digital pics are too clean and lifeless for my taste.
06-04-2009, 07:13 AM   #27
Remember those Dx0 marks, Nikon D300 Set Iso 3200 = Iso 2000 Pentax K20D Set Iso 3200 = Iso 2700
So compare Iso 4500 on the nikon to pentax Iso 3200 instad. (if K-7 keeps its "accurat" iso value")
06-05-2009, 12:15 AM   #28
wll
QuoteOriginally posted by Art Vandelay II Quote
Art,
I'm with you ... the high iso shots, (3200 and 6400) remind me of film, very tight grain and no banding ... I can live with that. We all want noise free at 6400 but with present technology that is not going to happen (maybe in a couple of years, but not now). I'm very much looking forward to seeing some low light stuff at 3200 to 6400 at 1/8 to 1/30 shutter speeds.
Yes, I've done some concert stuff where the lighting is horrific, and of course no flash is allowed. There are times when 1/8 of a second at high iso (1600 Pentax Ds) is all I had. I never used my K10D's at high iso's because they could not handle it - that is the main reason I sold them. The K20D is MUCH MUCH better, as I matter of fact IMHO you can't compare them - I'm very happy with the K20D and it looks like I'll be VERY happy with the K-7 when they hit our shores.
wll
06-05-2009, 01:41 AM   #29
QuoteOriginally posted by gazonk Quote
its not a matter of what aps-c camera is better.. its a matter of whats useable and acceptable, in any camera..
but that would be entirely dependant upon what the image is used for, so would be entirely subjective and up to each individual photographer to define.
if some one is shooting for their only enjoyment and pleasure then they may be happy with the 3200 noise levels.
but, if you havng to publish photos, then even the iso800 shots wont make the grade - far to much noise in the shadow areas.
so again - whats usable or not usable depends entirely upon the use of the photograph, and subjective to the photographers own level of acceptance.
whilst I may be happy with the noise in a certain photo, you may reject it as too much noise, and obviously the other way round too.
06-05-2009, 02:39 AM   #30
er1kksen's Avatar
If that's the hard and set case, why do I notice copious amounts of noise and/or evidence of strong noise reduction in photos in magazines on a regular basis? I think a lot of publications place more value on what the picture is of than how noisy it is.
pentax news, pentax rumors
K-x jpeg vs raw high iso question barondla Pentax DSLR Discussion 6 08-12-2010 02:39 PM
K-7 high ISO Performance RAW shang Pentax DSLR Discussion 28 07-04-2010 12:27 PM
K-7 HIGH ISO NR In RAW Christopher M.W.T Pentax DSLR Discussion 2 06-06-2010 05:19 PM
KX vs K7 in RAW HIGH ISO? Any real difference? Silat Shooter Pentax DSLR Discussion 5 12-03-2009 07:44 PM
K20D raw files at high ISO Martynas Pentax News and Rumors 21 02-01-2008 05:45 PM
All times are GMT -7. The time now is 08:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
