Originally posted by falconeye We (ie., my company) haven't decided yet if we will produce a movie preproduction filter. If so, a stabilizing filter would be required, ie., the fast alignment code, after some quality improvements (in the rotation part) which l left out. It would only be after a comparison to deshaker and iMovie that we can decide to release my intellectual property into the open source (otherwise, the code would have shown up in my blog already -- and the other shareholders wouldn't be amused exactly
). But the CHDK idea is in my records now
btw, does the CHDK platform feature enough memory to process three full blown images in memory? K-7 does.
i thought there might be more to it than just the impulse of doing it, that's why i tried to be diplomatic in stating the opensource-related idea
. it would be cool, but i understand, not everything can be oss, i guess.
chdk as far as i understand is quite varied as far as what hardware is underneath, depending on the camera on which it is running. as there is a whole range of powershots supported, i couldn't tell if all have a buffer big enough for 3 images, or bigger (but i can guess some will have, as there are compacts these days capable of shooting 3fps iirc). i guess that would be essential for speed, but maybe it could be tricked by processing only two pictures at a time somehow, i understand swapping(paging) in and out all the time would kill all real time goodness
Quote: Didn't I disguise well enough as a photographer?
aheeem.. well, no. too rational, too straight to the essence of things, typical behavior of somebody used to understanding "exactly how the world works", and knowing when he doesn't understand exactly, that's not something you see everyday, i could spot you from miles
Quote: Actually, I said on several occasions that I hold a PhD in Theoretical Physics. I once was one of Europe's better known computer architects, too. I now run a software and consultancy company. And Pentaxian from first hour
'nough said 'bout me, I guess ...
it might be that i did catch one of those allusions (not outright statements), i am not entirely sure, i might be cheating a bit here
. nevertheless, what i said above still holds true: it's written all over you
Quote: As for Fortran ... James Gosling (father of Java) some time ago wrote a Fortran parser because Fortran can still produce the fastest code. You wouldn't believe how lightning fast an XML parser can be -- if written in Fortran
IMHO, Fortran should be part of the standard repository of every decent computer scientist. I know some who can write Fortran benchmark code but are no physicists or engineers at all. And it will become hard to effectively program a thousand core processor w/o a data-parallel language like Fortran anyway.
tell that to physics students these days "why do they teach us fortran. what the hell is fortran? that's from the sixties. there's c++ now, and what's wrong with visual basic? ****ing dinosaurs..". you don't know if you should laugh or cry, really
. being aware of what fortran is, and what advantages it still has is a (cumulative) dead giveaway that somebody has at least something to do with physics.
so to conclude: stay away from direct unarguable statements, don't be afraid to contradict what you just said two paragraphs before, don't make any sense most of the time, bring irrelevant arguments into a discussion and stick to them as if they were the source of all truth, and never ever mention fortran making it obvious you actually know what it is (you can mention it ironically, like referring to some old piece of broken pottery everybody knows is long obsoleted and useless because now there is tap water available, but once it's obvious you actually _know_ what you're talking about, you're tagged), and you'll be fine, probably able to pass for anything, not only a photographer
