06-26-2009, 11:36 PM   #1
thibs's Avatar
Chasseur d'Images K-7 'in hands' preview
Got my copy of latest Chasseur d'Images preview.
I will put down here what I find interesting from the article. No, I will not translate the whole thing, wouldn't be correct, just what we did not know or anything else interesting.
  1. D-LI90 battery a lot more compact than D-LI50 but D-LI90 more powerful (1820mAh instead of 1620 mAh).
  2. Using viewfinder with eyeglass is totally possible although you need to press the glass against the eyepiece to view it all. Still, high-end viewfinder they say and brightness is good thanks to the prism.
  3. Focussing screen can of course be changed. Could be a bit better a smallest apertures but it allows a high level contrast, making it easy to notice the transition focussed/not focussed.
  4. Screen easily readable even when the camera is used in various positions usually making the screen difficult to read. Its high definition allows a powerfull zoom function for checking focussing state.
  5. They love the choice for Tungsten WB
  6. They love the histogram with blown highlights...
  7. They love auto horizon correction and sensor manual move, easier than toying with the tripod ballhead.
  8. 'The new user interface has seduced us [...] very efficient !' (buttons etc.)
  9. The electronic DOF preview, once used can be directly saved to the card if it suits the photographer, rather than having to take one more picture.
Everything else is known already, no point in stating them again.
Of course this is translated from french, so please take this into account, my enhlish isn't bad but no way my primary language.
Source: Chasseur d'Images, issue n.315, july 2009.
06-27-2009, 12:08 AM   #2
Asahiflex's Avatar
QuoteOriginally posted by thibs Quote
Thanks for the information! The last one (no. 9) is possible in my K20D too, I believe. But did CdA find any faults/drawbacks in the K-7? You mentioned not one single con.
06-27-2009, 12:20 AM   #3
thibs's Avatar
QuoteOriginally posted by Asahiflex Quote
Well usual ones we know about already:
  • no AF in Video
  • 1/180 X sync
  • No ratio in wireless flash mode
  • Not possible to use the fine framing function to correct a misaligned viewfinder
  • Slow Cd-AF
  • Green back illuminated LCD (they prefer orange)
  • bad effiency of Anti dust function
They like (on top of what I already wrote)
  • 100% prism
  • All lenses stabilized
  • rather light, well manufactured and compact body
  • WR including the kit lenses (and body)
  • Ergonomy (direct access buttons, chaning setting with wheel from the Info menu etc.)
  • Hi rez Screen
  • level displauy and level correction
  • Fine DR adjustment and HDR
  • HDMI
  • 21 fps mode could be useful
  • Digital preview can be saved
  • Good buffer and speedy fps
06-27-2009, 12:34 AM   #4
Mike.P®'s Avatar
  • Slow Cd-AF
Well I for one didn't know the anti dust function was not good.
I thought Pentax were quoting that as a major improvement, like CD-AF.
06-27-2009, 06:58 AM   #5
thibs's Avatar
QuoteOriginally posted by Mike.P® Quote
As well, but then they might just asume it is the same as K20.
06-27-2009, 01:59 PM   #6
SuperAkuma's Avatar
  • no AF in Video
  • 1/180 X sync
  • Slow Cd-AF
  • 100% prism
  • Hi rez Screen
  • HDMI
I thought the K-7 does have AF in video, you just press the AF button.
http://www.imaging-resource.com/PRODS/K7/K7A.HTM
It is possible to lock exposure during video capture if required, and unusually the Pentax K-7 offers the ability to explicitly specify the desired aperture prior to capture starting. Contrast detection autofocus is possible during video shooting, but is not continuous; rather the user must trigger the autofocus to operate when required, with the lens likely to briefly seek around the focus point before locking. Finally, the image stabilization functionality of the Pentax K-7 can be used during video capture. We elaborate on this a little more below under Pentax K7 Video Recording.
06-27-2009, 02:17 PM   #7
QuoteOriginally posted by SuperAkuma Quote
Looks like it was removed from production FW.
06-28-2009, 01:49 PM   #8
falconeye's Avatar
  • - bad effiency of Anti dust function
  • + 21 fps mode could be useful
  • + Digital preview can be saved
Seems indeed that they copy-pasted some bits from their K20D review. I would have guessed that CdA does better
06-28-2009, 02:06 PM   #9
FotoPete's Avatar
about the K20D's 21fps (@1536x1024) burst mode, it seems to be the precursor for K-7's 1080i video which is shot at 30fps (@ the same 1536x1024 resolution). The images are now bundled and linked with sound to produce the mov file.
I did a quick google check and it seems there are programs that can break up a mov video file into its composite jpegs which is indeed an extra step but is one way of 'shooting' 1.5MP images at 30fps.
Perhaps a firmware update could allow a 30fps or even 20fps burst mode at a more useful 2MP or 3MP would be very advantageous.
06-28-2009, 05:09 PM   #10
falconeye's Avatar
QuoteOriginally posted by FotoPete Quote
Pete, you might be happier in looking at our "Quality of K-7 video thread" for all the glory details about this. And why such a firmware upgrade is impossible.
btw, quicktime (pro) allows you to save the .avi as a bunch of jpgs, one file per frame.
06-28-2009, 10:44 PM   #11
frank's Avatar
[LIST=1][*]D-LI90 battery a lot more compact than D-LI50 but D-LI90 more powerful (1820mAh instead of 1620 mAh).[*]...
Another thing is about the battery. When put K-7 battery (D-LI90) and K20D battery (D-LI50) side by side, the D-LI90 is just a little bit slimmer than D-LI50 (due to their different shapes), but slightly taller. I wouldn't say it's a lot more compact than D-LI50:
06-29-2009, 12:40 AM   #12
thibs's Avatar
QuoteOriginally posted by frank Quote
That's what I thought based on previous comments.
Thank you for confirming that.
06-29-2009, 08:26 PM   #13
Thanks a lot, very interesting.
Could you elaborate on nr. 6 :
"They love the histogram with blown highlights..."
What is the improvement over K10/K20 here ?
chasseur, course, d-li90, love, pentax news, pentax rumors, preview, screen, viewfinder
Pentax K-5 Hands-on preview falconeye Pentax News and Rumors 87 10-08-2010 11:36 AM
Chasseur d'Images KX Review thibs Pentax News and Rumors 7 12-22-2009 02:36 AM
K-x review in Chasseur d'Images sceduled for next month but... 5 stars already !! thibs Pentax News and Rumors 1 11-29-2009 04:11 AM
Hands-on preview of K-7 available at Imaging Resource: "quantum leap for Pentax's SLR cateto Pentax News and Rumors 3 05-20-2009 07:55 PM
regional competition images... and a sneak preview of a possible portfolio image! Marc Langille Post Your Photos! 27 07-18-2008 08:13 AM
All times are GMT -7. The time now is 03:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
