10-21-2009, 07:41 PM   #1
inferno10's Avatar
Pentax K-7 firmware version 1.02 is out!
Pentax just released version 1.02 of the K-7 firmware. The main feature addition is a second fine sharpness adjustment mode:
Details here: Latest K-7 Firmware Update : Software Downloads : PENTAX
- Jason
10-21-2009, 09:26 PM   #2
right on, thanks for the news
10-21-2009, 10:08 PM   #3
Hah, I'd just upgraded the K-7 I received today to 1.13 literally 3 hours ago.
10-21-2009, 10:36 PM   #4
xhanatos's Avatar
Thanks for the heads up.
Pentax needs a proofreader:
"After formatting the SD/SDHC card, copy the fwdc204b.bin file to the route directory of the SD/SDHC card."
10-21-2009, 10:44 PM   #5
Would be really handly if they a) gave us an actual changelog and b) explained what "Fine Sharpness 2" does.
10-22-2009, 02:36 AM   #6
This is the most important for me:
Improved operational stability when using the optional D-BG4 battery grip (e.g. the D-BG4 rear e-dial may become non-responsive in rare circumstances).
I had the D-BG4 rear e-dial become non-responsive a few times, and I was fearing a faulty grip... Good to see all it took was a firmware fix.
Wim
10-22-2009, 10:58 AM   #7
Does fine sharpness 2 only work in JPG mode?
How about speeding up the preview display when we have lens corrections turned on in RAW mode ... right now it takes forever to process and display the image so this feature is useless to me.
10-22-2009, 12:12 PM   #8
As far as I know, all of those controls (contrast, saturation, sharpness, etc) only work in JPEG.
10-22-2009, 04:39 PM   #9
If you use Pentax Digital Utility, the RAW image will be tagged, so the converter will be able to use the information.
10-22-2009, 04:52 PM   #10
Arpe's Avatar
QuoteOriginally posted by deadwolfbones Quote
I'm with you on that. But do they ever explain what Fine Sharpness (1) even does?
10-22-2009, 11:08 PM   #11
QuoteOriginally posted by Arpe Quote
I don't think "they" ever did, but it's been explicated by others well enough.
10-23-2009, 12:32 AM   #12
thibs's Avatar
The reason why it takes time even in Raw mode is in fact very logical (which doesn't mean it shouldn't be fixed, I'm just explaining what it is so now).
Any Raw file (DNG or PEF) has a Jpeg embedded into it for preview purposes (on camera or on the computer) without the need the process the whole RAW (which would render preview of file a lot slower on camera). Since the Jpeg needs to be embedded, it is processed for distortion/CA as if the camera was in Raw mode.
There're two solutions to this problem IMO and could be asked to Pentax for implementation:
* Have an option NOT to embed the jpeg in to the raw (but preview will be slow)
* Have an option NOT to process the embedded Jpeg (but you won't be able to check if anything was corrected).
Just my 2 cents.. Falk? Any input?
10-23-2009, 03:54 AM   #13
falconeye's Avatar
QuoteOriginally posted by thibs Quote
I think thibs is correct in his analysis.
I consider it a bug as well. At least there should be an option to discard corrections except for meta data inclusion.
Isn't it possible to enable correction in post processing (using DCU4) even if it was off in the camera? Maybe, setting a flag is enough to get the feature in LR.
10-23-2009, 04:00 AM   #14
falconeye's Avatar
I was one of those providing an explaination.
However, I have just seen the remark that "Sharpness" is available in K-x video recording while "Fine Sharpness" is not (it is in the manual).
I conclude that "Fine Sharpness" is more computationally intensive than "Sharpness". This contradicts my earlier explaination where both are USM with differing parameters. Seems "Sharpness" is no USM at all.
I am now more inclined to believe that "Sharpness" was an early and simple sharpening method used on the then slower processors. Now superseeded by "Fine Sharpness" which is more computationally intensive. One probably shouldn't compare the different sharpening methods at equal setting.
So, a setting of light "Fine Sharpening" may be superior to a setting of strong "Sharpening".
10-23-2009, 06:15 AM   #15
Mister Guy's Avatar
Based on the descriptions, it sounds like Sharpening is USM, while Fine Sharpening is USM with an edge mask.
firmware, k-7, pentax, pentax news, pentax rumors, version
What firmware version does your K-5 have? adamfogerty Pentax K-5 5 10-21-2010 08:57 PM
K-7 Firmware Version ceojr Pentax DSLR Discussion 3 09-24-2010 05:10 AM
K-7 Upgrade Firmware Version 1.03 jogiba Video and Pentax HDSLRs 7 03-21-2010 12:35 PM
Checking KX firmware version in camera? Ira Pentax DSLR Discussion 20 03-02-2010 04:44 PM
How can I see the firmware version? Palu Guimaraes Pentax DSLR Discussion 2 04-11-2007 05:05 PM
All times are GMT -7. The time now is 09:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
