11-28-2009, 10:06 AM   #31
QuoteOriginally posted by Ole Quote
From the diagram the final product looks very much like these images of a prototype.
I wonder if the leak would know what the two taped-over buttons are for.
I like that the EV, ISO and green buttons are placed as on the K-7; makes it easy to switch between the too cameras in the field.
One interesting observation is that the camera strap studs seem to be similar to those on the LX ...where you had a snap on bracket on the camera strap. So much better than the split ring as on the K-7.
11-28-2009, 10:15 AM   #32
monochrome's Avatar
Viral Marketing Strategy
Interesting that this has "Leaked."
Reminds me of the K-7 viral marketing of leaked blurry images, then better images, then "Coming Soon" postings on the Pentax websites.
Weren't there three or four threads here that went each to the longest threads ever?
11-29-2009, 09:21 AM   #33
Miserere's Avatar
QuoteOriginally posted by jonny1986 Quote
My consideration:
-these camera is comparabe only with leica s system...these cameras are big but not more than a canon 1d series for example...theya are portable and they can be used easily as travel camera or strret cameras for reportage for example.
I'm afraid not. The Leica S2 is indeed very small for a MF digital (it's smaller than a Nikon D700!), but the Pentax 645D is cubic in shape, probably quite heavy, definitely larger than the S2, and not at all what I would call portable.
I think this was Pentax's biggest mistake with the camera, wanting to make it backwards compatible, and thus preserving the registration distance of the original 645. Leica designed the S2 from the ground up, and in doing so produced the most compact medium format digital camera in the market...by far!
11-29-2009, 09:49 AM   #34
thibs's Avatar
QuoteOriginally posted by Miserere Quote
MF? Biffer than 35mm, yes. MF?
Maybe SMF. Small MF LOL.
11-29-2009, 10:37 AM   #35
artemapei's Avatar
QuoteOriginally posted by thibs Quote
it is smaller than d3, but not d700 - the most compact 645 system...
11-29-2009, 12:44 PM   #36
The Leica is 23k without a lens. They don't have a lens for under 4k. That's a whole different price range. Pentax would be competing at a very different price point.
11-29-2009, 01:53 PM   #37
thibs's Avatar
QuoteOriginally posted by artemapei Quote
Sorry, I should have been more precise, I was pointing to sensor size...
S2 is 30x45mm
645D (according to current information ie 39MP Kodak CCD) is 46x61mm.
I wouldn't call S2 an medium format IMO.
11-29-2009, 02:07 PM   #38
gazonk's Avatar
Are you sure? That would make it more-than-full-frame MF (the 645 film size is smaller at 56 x 41.5). It would also make 76 mm the normal lens focal length, i.e. the 55mm on the road map would then be a WA lens.
11-29-2009, 02:13 PM   #39
You may not like it, but it isn't a mistake.
Pentax is clearly looking to make a splash with regard to features vs. price. One way to help with that is to actually have a large used lens market. Pentax hasn't been particularly fast to get to market with any of their lenses of late, and without the used lens market, I suspect they'd have zero chance of success, regardless of price.
The leica may may be smaller, but most MF cameras are not, and you don't exactly see leica taking over the market by selling small at a high price point.
The thing I'd be most concerned about is if the electronics are the same as the k-7. USing the same electronics doens't hurt you in a film camera because focusing and metering are pretty much equivalent tasks. In a digital camera, you now have to process 39MP vs 14MP. Unless they have parallel units, you are going to see a lot of the numbers drop with the camera.
11-29-2009, 02:24 PM   #40
I sure hope that the camera would be fast enough using SD cards.
11-29-2009, 02:34 PM   #41
It wouldn't worry me as I'm not in the market for it anyway but I believe that if the 645D came out being about to operate at a little under 40% the K-7 speed (1.9 fps, I think - slaughter my maths if need be) then it would already beat everything else out there (again, please tell me if I'm wrong).
Having said that, if Pentax go with the Kodak 39MP then the speed bottleneck might be before you even get out of the sensor, nobody else AFAIK has managed anything stunning here. As for noise, let us say that if there was a bigger version of the K-7 sensor in an MF camera nobody would be bitching about bad high-ISO quality, they'd be falling over themselves to have it.
When tooling up for MF, nobody's hunting around for 8fps, they're settling for 1.
11-29-2009, 03:43 PM   #42
Miserere's Avatar
Where did you get this info? Everything I've read points to a 36x48mm sensor, including the 55mm "kit lens" (the diagonal of this sensor is 60mm).
Maybe not, but all digital medium format sensors right now are cropped, i.e., not the same size as film medium format. Maybe we should call them DMF and reserve MF for film.
11-29-2009, 05:17 PM   #43
RuiC's Avatar
My guess for one of the buttons is to switch to FX format, using D/FA lenses via a fully auto up-converter, so fulfilling the needs of the vast FF fans.
Rui
11-29-2009, 05:36 PM   #44
QuoteOriginally posted by RuiC Quote
Rui
Now there's a nifty concept - a crop mode for FF.
11-29-2009, 09:18 PM   #45
rparmar's Avatar
No, I don't think so.
I summarised the available info in the article Pentax 645 Digital On The Horizon. There's a nice table there with a comparison of sensor sizes.
645D is expected to be 4836mm, which is a diagonal of 2.1x APS-C. 35mm is 3624mm or 1.5x APS-C.
645d, pentax, pentax 645d user, pentax news, pentax rumors, user
645D English User Manual? etrigan63 Pentax Medium Format 3 10-08-2010 11:44 AM
For Sale - Sold: Pentax SMC-DA 55-300mm with hood & user manual arm_jstp Sold Items 4 08-28-2010 07:46 AM
For Sale - Sold: Pentax SF10 in good condition with user manual (Worldwide) jjdgti Sold Items 2 06-09-2010 12:58 PM
K-7 User Manual agkchang Pentax DSLR Discussion 7 06-24-2009 11:59 AM
Gimp User Manual Rodney9 Digital Processing, Software, and Printing 2 08-24-2008 05:11 AM
All times are GMT -7. The time now is 04:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
